Deep Fryers
Problem for Deep Fryers
Generic problem for all Deep Fryers
Deep-fryer thermostat
By kervin623 on Jan 13, 2009
Yesterday I replaced the thermostat in my wife's deep fryer with an American Range, model E-289. When I turned it on, there was a brief flash and it wouldn't get hot.
It's wired correctly I assume, unless it makes a difference on which wire goes from the thermostat to the heating element.
Is it possible that this E-289 is a 110V unit? I ordered it online, and the people there couldn't tell me what the voltage rating was, and I assumed it was designed for 220 Volts. I cannot find any specs for it online. Do you know?
Another thing; if the heating element is shot, or shorted out, will that cause the thermostat to short out also?
Help!!
Comments:
Jan 17, 2009
- hkarameh,
Now I know the problem. I ordered that thermostat in a great rush, and that was my mistake. Let me rephrase that. My messing with it was the mistake. I'm a damn bee-keeper, not an electrician.
Anyway, after I took it out and replaced it with a used one that my son-in-law had found, I took it apart to see if I could tell what the hell had happened to it.
Aha!
I saw a very small fuse/capacitor/thermocouple, whatever, located between the prongs that close/open the circuit to the heat element. The fuse thingy appeared to be still good, but the wire that connected it to the prongs was blackened, and about 1/8" was gone.
After that, my curiosity really got riled up, and I kept web-searching until I found a clue. It seems that the American Range thermostat model E289 that I tried to install is designed for a "millivolt system" only. Whatever the hell that is.
My next mission is to try and find some literature about how this type of TS works, because I could see nothing connecting the power to the contacts that tell the element to switch on/off.
Interesting stuff.
Solution #1
posted on Jan 14, 2009
Somewhat Helpful)
hkarameh
Rank: Wiz
Rating: 85%, 32 votes
It is possible that the heater is shortened and it burns thermostat. Thermostat's are usually bimetal type mounted on ceramic so voltage does not matter a much.
Was this helpful?
Yes
No
Popular Solutions for Deep Fryers
Questions and Unsolved Problems for Deep Fryers
Answer
the err bottom keep comimg on when trying to get it started.
Answer
euro pro 1052 2 litter dose the oil go on top of the element Brand Euro Pro 1052
Answer
The control module will not turn on the socket works and the cord is secure, and the module is... (More)
Answer
I assume the red button that sits directly behind the star deep fat fryer is the high limit switch,... (More)
Answer
no instructions on assembly on 815-4000s
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Deep Fryers:
Top Deep Fryer Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Deep Fryer Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
