Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Powersteamer roller brusch not turning
My Bissell powersteamer --- power comes on BUT brush not turning
and no suction!!
where is the nearest repair shop in Toronto?
pls help....
  • yhpark0485 Jan 19, 2009
    Thank you for your reply.
    I discovered the flat belt was broken... so | replaced it yesterday. Bruch stared to turn but
    quickly jammed by teethed other belt dislocated from the pulley gear. I will try it again tommorrow.. thanks for your kind reply....
  • 19,396 Answers
If you have not fixed the problem yet, here is a list of authorized repair in Toronto:
Toronto Ontario, Canada Bissell Vacuum Parts
bissel - Services - Repair
Vacuum Cleaner Service & Repair - Toronto
Posted on Jan 23, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! Good Info. for Tomorrows Repair! The brush roll is driven by a cogged belt, the brush roll will also have these cogs. If they look all right, then check the end of the pump, it has a dual pulley on it, one for the flat pump belt, and the other for a cogged belt. If the cogs are wore away or that part of the pulley broke off, then you will have to replace the pump. That pulley only comes with a pump.
Posted on Jan 21, 2009
  • 15,935 Answers
If you have additional questions, please re-post.
Thank you for using Fixya!
  • 728 Answers
The reason your brush is not turning is because your belt is probably broken or something is clogging up the brush and causing it to stop spinning and may be blocking suction. Usually on the side or back of the vacuum it will tell you what belt size to use, and all you have to do is find the size of your belt number and look on this site and you can purchase it from there: http://shop.ebay.com/items/?_nkw=vacuum+belt+for+bissell&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=vacuum+belt&_osacat=0
Then you can go to www.youtube.com and type in how to install a vacuum belt, and if you want to save money, you can do it yourself.
Posted on Jan 16, 2009
    Novelist:
  • 115 Answers
You may want to try one of the places on this link. I suspect the roller brush is jammed or has a broken belt. As far as no suction, make sure that the 'rinse water' tank is properly seated and that it's seal and the seal behind the big clear plastic plate in front aren't leaking. That's a common problem on these. Good luck.
Bissell powersteamer model 1697 not extracting water
Check all suction connections. And make sure no debris in suction ports
Nov 01, 2013 | Bissell 1693 PowerSteamer Upright Vacuum
Need to replace a brush belt
Accessories and replacement parts for your Bissell 1697 Powersteamer Pro are available here:
http://canada.bissell.com/Products/p/powersteamer+pr/ak/replacementparts/Product.aspx
Your User Guide is also available at:
http://canada.bissell.com/images/UserGuides/1697C.pdf
Refer to page 15 for instructions on how to replace your brush belt.
Apr 03, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
ROLLER BRUSH NOT WORKING (BISSELL POWERSTEAMER PRO DELUXE )
The belt may be broken. Follow the link below to belt inspection video on www.bissell.com.
http://www.bissell.com/VideoRating.aspx?id=1555
Oct 05, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Is there any reason the water won't come out?
You need to replace the pump belt, that is why the water is not dispensing and you need to replace the brush belt, that is why the brush isn't spinning. Here are the belts you need.
Bissell Powersteamer Belts
Feb 04, 2010 | Bissell Powersteamer 1694 Upright Vacuum
Can a bissell powersteamer work if the belt on the
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
retr
Nov 17, 2009 | Bissell 1699 ProHeat Clear View Upright...
No Suction/Brush not spinning on Bissell Powersteamer Pro Deluxeb
make sure hoses are clear and check belt
Oct 08, 2009 | Vacuums
Water and cleaning fluid not coming out
water head pluged use tooth brush and hot hot water ,on bottem of vacc find water heads brush until clean
May 06, 2009 | Bissell Powersteamer 1694 Upright Vacuum
Brush not turning and no suctions !
If the cogs on the belt and brush roll are ok, then probably the cogs on the pulley are worn off, or the pump isn't turning, is the flat belt ok? If all of this is ok, then replace the pump, part # 2107181If no suction, is the black oblong gasket on the top of the clear window. It seals the gap between the tank and the window, no suction if it is gone. Also should be a red plastic screen on the edge of the tank lid, it may be clogged.
Jan 16, 2009 | Bissell 1692 PowerSteamer Upright Vacuum
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
107 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
