Question about Samsung CLP 300 Laser Printer
Color problem! When I print in color,halve of the print is yellow/green,no red. the other side of the print is oke.
    President:
  • 670 Answers
If you the image is faded and your toner supply is good, the problem is the developer blades in the imaging unit. It sounds like the magenta blade needs to be cleaned. During the normal use of the printer, there is a buildup of toner that sticks on the developer blade. The developer blade meters the amount of toner that gets to the drum that ultimately makes it to the paper. As the toner buildup increases on the blade, less and less toner that gets to the drum cause the image to fade.
To fix this problem you will need to disassemble the imaging unit and clean the blades or buy a new imaging unit. I have clean my blades and I have a document to show you if you are handy.
Posted on Feb 14, 2009
Color code on isuzu rodeo 2002 ls
You should have a plate or sticker under the hood on the firewall on the drivers side that lists the color code. With many manufacturers there may be several variants to the stock color throughout the model year so it's possible that even with the color code your final color may not match exact, but it will be close. If you're still not able to find the color code on your vehicle, try removing the fuel filler door and seeing if your paint supplier can camera match it for you.
Apr 02, 2014 | Isuzu Rodeo Cars & Trucks
My printer is Fuji xerox 1250, Recently i have a problem for the color issue, we tried color Calibration, We changed drum, we even reset to manufacturer default setting (by press 0+ green button and...
It seems your yellow color is not function correctly. Need to check yellow color feed and its linkage to deliver ink to your paper. Looks like it almost clog up that cause very light color in your paper. Again please check completely your color feeds.
Regards,
Dec 15, 2010 | Fuji Office Equipment & Supplies
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
Mar 05, 2010 | Dell 810 All-In-One InkJet Printer
No red
the color red is a mix of two color. so run the cleaning tool on the printer
Dec 12, 2009 | HP PSC 2175 All-In-One InkJet Printer
INK JET PRINTER NOT PRINTING RED - GREEN HUE ALL OVER
the mixture of red is a combination of magenta and yellow ink or toner, if either one of these color is out of quantity or not working, chances are you will not get the right color. hope this helps.
Nov 19, 2009 | Epson Stylus C88 InkJet Photo Printer
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Will not print true colors especially red and blue and green
replace the two ink caterage to a new one. it could be from the ink you refill that is if you refilled. bye
May 22, 2009 | Compaq Inkjet IJ600 Printer
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
Samsung CLP 300 Laser Printer Logo
304 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
