My sony STR-DH830 receiver will automatically shut off after 15 minutes when I play either my cd player or ipod. I have turned off the auto stanby and the sleep timer.
4 Suggested Answers
  • 85 Answers
SOURCE: operating instructions for sony str-d565 receiver
this is a link just make sure to disable protected mode in internet explorer sometimes it has problems with links
http://www.docs.sony.com/release/STRD665.PDF
Posted on Feb 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: STR-DE475 receiver flashes "PROTECT" when turned on
Protection is usually a sign of overheating or something is wrong at the power amplifier's output.
Theory: Protection is a delay and sometimes an internal test to allow the electronics to stabilize during power up before they are allowed to interact with the speakers. The most common cause of it remaining ON is that a speaker cable pair is shorted. Some isolation is required...
1. Turn the Power OFF.
2. Disconnect each set of the speaker wires that are directly attached to the receiver. Mark them so you remember where each one went. pay special attention to which conductor is on "+" or "POS" and which is on "-", "COM" or "Ground". You may elect to disconnect them one pair at a time if your sytem is complex and you don't want to lose track of where things were.
Turn the Power ON. Is the "Protect" indication gone from the display?
If YES, you have a shorted speaker wire or speaker. To isolate the specific cause:
2. Attach ONE speaker wire pair at a time and test it by turning the Receiver ON. When the "Protect" light returns you have isolated at least one of the cause(s). Disconnect the defective speaker cable and continue isolation of all speaker cables. Visually examine the cable at both ends for frayed wires that could touch each other or contact metal on the receiver or other objects.
To isolate further within the cable/speaker pair - disconnect the speaker end of the cable on the failing path. Try another cable that you know works, or at least one that doesn't cause Protection to stay on.
If you're electrically savvy and have a Digital Volt/Ohm Meter you can troubleshoot the short(s) with it.
If NO, there is probably an internal problem.
Is it solid or does it come on after the Receiver has been ON awhile.
It could be overheating.
Is the unit hot to the touch?
Is there a cooling device (fan)?
Is it stopped or clogged with dust?
Is there adequate ventilation around the unit for air to flow?
Clean any ventilation slots on the top and bottom of the unit.
Avoid stacking components that produce heat under an amplifier or receiver. Their heat rises. Also keep them away from other heat sources like like home heating vents and radiators.
Problem solid and NOT related to the speakers or heat: internal malfunction.
Let me know.
Posted on Apr 02, 2009
SOURCE: I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Posted on May 01, 2009
Why does my Sony STR-K750P AV receiver automatically switch to Video 2?
Some models of systems will switch to a new source automatically if the source sees a new signal coming on. Try disconnecting the device on your Video 2 to see if this is the case.
I have seen the IC or component(s) in the switching circuits become defective and cause unpredictable or faulty operation. This can also be a fault condition you are seeing.
Apr 02, 2017 | Sony Str-k750p Av Reveiver
Have a sony trinitron tv which turns off automatically and sporadically on average every 15 minutes
Hello
Most of the sony Tv power supplys are based on STR type regulators. Regulation of an STR is very accurate and if any overload inside the ciruit board of the TV, will be sensed by the STR and will shut off all the supply to the system itself. From your complaint we understands that there is some sort of short, not a direct short, is in your tv. Usually it may related to horizontal output transistor. At first it will work fine, but as time pass on, it will get over heated, passes more current, and place a short like circustance to the power supply rail itself, and as described above, STR will sense it and will shut down the system. After some time, say after 10 or 15 minutes, after the heat generated has gone off, the TV will again switch on, and the cycle will be repeated. You just call a technican and keep this in mind, and ask him to repair the same.
Oct 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The digital sound is off after 1 houre str de sony str de 485
It sounds like the receiver is either failing or going into a thermal protection mode.
There should be NO reason why the input source (digital versus analog) should make a difference unless you play the digital sources obscenely louder than the analog ones.
If you suspect heat, you should be able to feel it.
Can you verify that the digital sources ONLY do this?
Mar 01, 2010 | Sony STR-DE485 Receiver
Want to play my ipod through sony str-de135 receiver
Get a headpone to rca cable (radio shack or best buy) and use any input on the rear of the receiver except phono. You will need to turn the ipod to near max volume.
Nov 28, 2009 | Sony STR-DE135 Receiver
Stops working after a few mins with cd player playing
One of three things: speaker wire short, shorted/or blown speaker, or a bad output chip. First and easiest way to check is to disconnect all speakers, turn it on, turn it up, and wait. If that's ok, begin connecting one speaker at a time with the unit off, then turn on and play. When you get to the speaker or wire with the problem, it will short and go into protection. Disconnect all speaker wires again and only hook up the speaker that shorted the receiver and test. If it shorts, swap speakers with the same wire and test again. If a different speaker on the same wire causes the unit to short, replace the wire. if it doesn't, you need to test the speaker with a multimeter or disassemble if possible, check the wiring internally on the speaker. Check the impedance, should be 8ohms or 6ohms depending on the drivers. then check for resistance. If your meter says 1... it's shorted and needs to be replaced. Hope this helps
May 25, 2009 | Sony STR-V444ES Receiver
See add details
Since the receiver eventually works, the delay circuit is failing. This is a circuit that allows the power supply to settle down before kicking in the output relay. This prevents the "pop" that was sometimes heard on older units. This should be a simple and inexpensive repair probably requiring the replacement of a couple of small capacitors in that delay/protection circuit.
Dan
Mar 09, 2009 | Sony STR-DE935
Playing ipod on sony str-de595 receiver
You need a 3.5mm mini jack coupler lead with phono plugs on end plug one end into your headphone output on ipod and phonos into your amp lead must be stereo
Dec 22, 2008 | Sony STR-DE595 5-Channel Amplifier
How do i hook up my ipod to a sony STR-DE597 6.1 channel reciever?
have u checked the COMPATIBILITY of the IPOD with your system(receiver/amplifier). the software of some models is not compatible withyour respective receivers.
Go to their sites for software upgrades.bye.
Oct 31, 2007 | Sony STR-DE597 Receiver
69 people viewed this question
 Grubhead
Grubhead
