Why my ac is on but its not cold - Heating & Cooling
  • 21 Answers
Check the condensing unit (the outdoor section). There are two motors in this unit, a fan and a compressor. If both are not running then you may have a blown fuse or circuit breaker. Fuses are sometimes located in the disconnect box next to the condensor. The circuit breaker is located in your main breaker box. If only one motor is running or neither is running but there are no blown fuses or breakers then you probably have a bad start capacitor. This capacitor should be replaced by a someone knowledgeable in residential 220VAC equipment.
Posted on Jan 13, 2009
Why does My thermostat Not switch between ac,heat,defrost . there's cold air coming out of vents but not cold enough to be ac. Initially when this started the ac was blowing hot air
If the air flow cannot be controlled from vent/defrost/floor you may have a blend door issue. This is an electric motor that operates a door in the heating system to control airflow. There are usually 3 motors controlling airflow direction,heat and recirculation. The Ac not blowing cold may also be another problem. If the AC is operational, the compressor will be engaged and the Ac low pressure line under the hood will bw cold. If this is all ok then a blend door issue should be suspected
May 09, 2015 | 2006 Jeep Grand Cherokee
03 grand am ac wont blow cold air
Two things are very likely to be your problem. Freon or compressor. Turn on the ac on cold and see if the compressor is engaging, if it is and stops and goes or if it doesn't. try to check the compression on the low side of your ac, the smallest plug where you service the ac. Or take it to an ac professional to get it refilled or checked. Remember, just because its blowing air, it doesn't mean its working. There are fans inside the car that push the cold air inside your vehicle and most of the time these will work, but that's not the only part required to blow cold air inside your car, the compressor is what makes the air cold.
Oct 09, 2014 | Cars & Trucks
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
No heat from vents
Heater blows cold?
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
Freeon is good dont know what else it could be. when its cold out the ac works fine but when its hot it doesn't blow cold? WTF
The ac will blow sold when its cold outside.It is just the air from the outside. You need to check to see if the ac clutch is turning when the ac is switch own.You may have a bad ac compressor
Mar 05, 2010 | 2002 Mitsubishi Lancer
No Cold air from 99 Montero Sport
replaced clutch, driver ac belts on 2000 montero sport a/c is still not blowing cold any ideas
Jun 30, 2009 | 1999 Mitsubishi Montero Sport
AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
Aug 25, 2008 | GMC Sierra Cars & Trucks
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
