Question about HTC Wildfire S Smartphone
Top power button not working on htc wildfire s
Have to press REALLY HARD to make it work
5 Suggested Answers
  • 117 Answers
SOURCE: I am having htc wildfire.
U CAN DOWNLOAD THE SOFTWARE FROM THE BELOW HTC SITE
http://www.htc.com/www/SupportDownload.aspx?p_id=316&cat=3&dl_id=1058
Posted on Dec 15, 2010
  • 1040 Answers
SOURCE: I am having htc wildfire. so i need pc suite for
hi,
Visit to the given link and download and install the "HTC Sync 3.0"...
http://www.htc.com/www/supportdownloadlist.aspx?p_id=316&act=sd&cat=all ...
hope this has helped you.. Please rate the answer. Thanks...
Posted on Jan 04, 2011
spoticatfish
  • 100 Answers
SOURCE: hi there my problem with htc
When you plug your phone in to the computer, a couple new icons should appear in your notification bar. Bring the notification bar down and click on the one to mount your phone as a drive. You may also need to turn on USB debugging.
Posted on Mar 02, 2011
  • 7 Answers
SOURCE: Where can I purchase a HARD copy User Manual for
hi bratt ,
you can download HTC wildfire user manual and print it.
http://www.htc.com/www/userguide.aspx?p_id=316
Regards,
Nimiaj
Posted on Jul 16, 2011
I've got an Intex pure spa hot tub and the air bubbles button isn't working but the LED screen is on??? Any suggestions?
  • Do the other buttons work fine?
  • Did you press REALLY hard and break it
  • Have you tried pressing it REALLY hard when its not broken- Probably a bad idea
  • if you have the know how and the bravery take the face plate off (MAKE SURE THE POWER IS OFF AND THE WHOLE THING IS UNPLUGGED)!!!!!1
  • check the wires going to the back panel of the screen Rusted, corroded? Might be covered under warranty - refer to manual or look-up based on how long you've had unit
Jun 05, 2015 | Intex Pool & Spa
The Start/Stop button is not working property
I've checked the manual but could finf if your on/off knob is by a pcb tiny on off knob or do you really year a hard click. http://www.vinylengine.com/library/numark/tt1510.shtml login and they know it, it's easy to make
Jun 14, 2014 | Numark TT1510 Turntable
In my wildfire s set sd & phone storage the mount sd card option is not working.in this menu total space is unavailable and available space is unavailable while the sd card is workin properly in other...
Delete all messages and call logs.......if still problem persists then probably there are some malware occupying your memory which creap in if u use internet on ur phone......solution is - factory restore ur phone after backing up only important data.....if this does not work then hard reset ur phone.....press vol. up, camera and power button together for a few seconds.......download/boot mode will appear......press menu or vol. down button and scroll down to CFT calliberation ...select using menu button......phone will restart....this should solve ur peoblem..
May 03, 2014 | HTC Wildfire Cell Phone
How can i open pattern lock of htc a510b
do a factory reset:
  1. With the HTC Wildfire turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
  2. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
  3. Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
  4. Press VOLUME UP to start the factory reset.
Mar 31, 2014 | HTC A510B Wildfire S Unlocked Black
Horn will work at times, but have to press down pretty hard, on the steering. I took off the front and can't really see what the problem is
This could be the pads on the steering wheel that operate the horn, they can wear out over time. You must be very careful if the vehicle has airbags in the steering column. IT could aslo be the wiring harness in the steering column, this is known as the clock spring.
Feb 22, 2014 | Ford Ranger Cars & Trucks
My htc wildfire is froze on the unlock screen , things load up in my status bar , but i cant slide my " unlock bar " neither up or down to unlock it .... i need advice! pleeeease help me :(
you can try a hard reset, but that method will reset the phone to factory settings and will delete all data on the phone so if you proceed with this method backup all data if possible and remove the sim card and any external memory cards.
1. Remove the battery, wait for a few seconds, then reinsert the battery.
2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
3. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Oct 17, 2013 | HTC Wildfire S White Metro Pcs Android...
I have a 2002 ford explorer and sometimes its hard to shift to drive and the brake lights don't work unless I press really hard on the pedal.
*Hard to shift:
-Possible the shift cable need to be adjusted.
*Brake light is no working unless step(press really hard).
-Need to adjust the brake light switch. It's too closed or stuck.
Mai
Aug 09, 2013 | 2002 Ford Explorer
Hard to press on break
See if the brake booster check valve works
Sounds like you have no vacuum,thus no power brakes
Dec 01, 2012 | 1994 Toyota Land Cruiser
Disgo is frozen on home screen and home icon keep flashing i cant do anything
Search google to do a hard reset, I had the problem and after doing a hard reset it helped me and my tablet is working fine now. I don't really remember which keys it was but there are three keys to keep pressed and after that it will reset your tablet and if everything is ok it should work perfectly after that.
It would be nice if the manufacturer would also put that in the manual, because when I received my tablet I had to calibrate the screen and that didn't really help me. Also the tablet was working really slow and took a lot of time for everything, plus the fact that the keyboard kept pressing all sorts of other keys then that I wanted to press.
I hope this will help you and that your tablet will work fine for you.
Let me know if you had any success.
Sep 08, 2012 | Disgo Tablets & eReaders
My metro pcs htc wildfire s is frozen on the unlock screen
try hard resetMaster reset using hardware buttons: HTC Wildfire SVERSION 4 Created on: 15-Aug-2011 09:21 by tmo_brian - Last Modified: 07-Mar-2012 16:29 by tmo_josh_m
To perform a hard reset using the hardware keys, follow these steps:
  • Note: A hard reset restores the original factory settings and erases content, including downloaded ringtones, images, programs, and contacts stored in the internal memory. This feature allows for resetting of sound profiles, display settings, and phone or memory card settings. However, if you want to try resetting some factory settings without losing any data, then clear system cache before a master reset.
  1. Back up all necessary data and synchronize files. See: Prepare for a master reset and back up data on Android
  2. If the phone is plugged into the charger or USB cable, unplug it.
  3. Remove the battery.
    • Important: Removing the battery is required. Turning off the phone with the Power key does not work, because of the Fast Boot feature.
  4. Re-insert the battery.
  5. Press and hold both the Volume Down key and the Power key. Do not release the volume key, continue on to step 6.
  6. Release the Volume Down key when the three Android images appear on the bottom of the screen. The following options display:
    • FASTBOOT
    • RECOVERY
    • CLEAR STORAGE
    • SIMLOCK
      • Note: If you are stuck on a screen that says 'HBOOT' and 'FASTBOOT' without any other options to choose from, it means you have pressed the Back button. To get to the regular options, press either the Power key on HBOOT or the Back button.
  7. Press the Volume Down key twice to select CLEAR STORAGE.
  8. Press the Power key to initiate the master reset.
  9. Press the Volume Up key to confirm Delete all user data.
  10. Wait as the device clears the user data then restarts.
DOC-25626
Aug 30, 2012 | HTC Wildfire S White Metro Pcs Android...
HTC Wildfire S Smartphone Logo
1,400 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
