Question about General Electric Hardware & Accessories
GE timers -how to set
How do you set this to come on and off at a certain time. Its a digital. Model # 15273
SOURCE: My GE 7-Day Digital Timer model 15086 flashes on
I just bought one today and installed it. It does the same thing - flashes the lights off and on. After some research on the net, it seems that the problem is that an old house is wired with two pole wiring and the new fixtures, (timers included) are 3 pole. The conclusion I have found is that it will not work in a 2 pole wired house. There supposedlly are timers available for 2 pole wiring. I hope this helps. If you find out anything different, please let me know.
Posted on Oct 19, 2009
SOURCE: how do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Posted on Dec 21, 2009
  • 10865 Answers
SOURCE: GE Digital Time Switch (15132) for basic landscape lighting
Leave the breaker off, remove the wires from the timer and just connect them. then turn the power on. Unless you have a short somewhere, the lights should come on. What you have just done is made the breaker your switch. If the breaker kicks you know to keep looking for a short as it is not the timer. Regards, Joe
Posted on Jan 13, 2010
SOURCE: GE digital timer model 15086 doe not work
This timer requires a neutral wire, it may or may not be present in the back of your box as a group of wire nutted whites. It is NOT the single white switch leg.
Posted on May 27, 2010
SOURCE: ge digital timer how do i set
http://www.jascoproducts.com
select support and enter the model number (15079) in the search field. the manual is downloadable. One thing the manual does not make clear is that the two plugs in this timer cannot be set independently of each other. Whatever two devices you plug in will go on and off at the same programmed setting.
Posted on Oct 04, 2010
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Set the hour on clock on GE electric stove
Service manual for GE DPSR473EW0WW dryer
the timer may be stuck at a certain place as they have points that at times tend to burn out and stick when the timer gets to that point. do the other settings work? some times the moister sensor will not sense dry clothes and keep running? as for ur drum noise that may be due to bad rollers or bad tensioner and belt depending on ur model and hopefully not bad bearings also a possibility
Jan 22, 2015 | GE Dryers
Where to purchase trippers for GE mechanical time switch model #15163?
This actually a Jasco 15163 and according to www.harwareandtools.com it takes a Jasco 15602 tripper set. This tripper set can be found for online order at http://www.jascoproducts.com/products/pc/Replacement-Timer-Tripper-2-pack-p1089.htm#.U9Ov2bHG-f415602webg2.jpg
Jul 03, 2014 | General Electric GE 56941 24-Hour Outdoor...
Owners Manual appears silent on two questions.
1) Question posted under Jasco GE timers.Timer is otherwise not identified as type, model or brand.Certainly this information shows on product manual.
2) Copy following link to help identify timer and download possible manual:http://waterheatertimer.org/GE-timers-and-manuals.html
3) Upward operational temperature for digital timers usually ranges 120-155 F. So this should not be issue in garage until global warming eliminates all electronic gadgets, batteries, and seriously affects electric transmission lines from power plant.
4) Downward operational temperature for digital timers vary widely by type and model number of timer.Some become unreliable at freezing. Some last 1 month in freezing. Some are rated to zero F. Some rated minus 10-40 F.
5) Smart plan is analog timer instead of digital timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#applianceThis type timer will operate on electric power, and not be affected by temperature fluctuations. However timing is not down-to-the-minute 7-day as with digital timers.Note appliance watt rating before buying timer.
6) Two-outlet plug-in timers are not 2-channel timers or 2 circuit.2-channel timer means that the timer can be programmed for two separate timing programs, with each timer program controlling separate load with separate schedule for each load.
7) Example 2-channel timer: Intermatic 1125 digital timer.Note operating temperature -40F to +155, making this especially hardened timer, with wide range timing applications excluding delay functions, But with 1 year limited warranty as is typical with most timers.
http://waterheatertimer.org/pdf/024_ET1100-sell-sheet.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 05, 2012 | Jasco 15079 SevenDay TwoOutlet Digital...
Need instructions to set time for 8 outlet power Strip timer Utilitech
Copy following link to identify power strip timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
Zilla, Utilitec, GE strip timers use basically the same format for programming.
For each ON time, there has to be a corresponding OFF time, and days for On and Off times cannot conflict.
Best guess: you have a conflict or incomplete on-off program.
With Zilla timer, there is added level of complexity since the ON-OFFs are set for different day and night outlets.
Add a comment with the exact timer model number so expert can read the manual alongside you.
Aug 31, 2012 | Hardware & Accessories
Ge smart timer-won't work after I changed off/time-no voltage to light
Hello Terry. Which GE digital timer do you have?
Copy following link to identify timer, and download manual.
Reset timer using reset button.
If timer has no voltage, then check outlet.
Check circuit breaker.
Check that light bulb is good.
If timer is plug-in type, then test outlet with circuit analyzer. Try timer in different outlet with different light.
Re-post question with timer model number, and things you have tried so far.
Jul 15, 2012 | Hardware & Accessories
Have set the timer to come on at the same time every day and off at the same time every day but when I put it Auto mode does not turn on. What step am I missing
You posted under GE dial-type power strip timer.
GE has 2 different models: 57698 & 15090
15090 has instruction manual, and 57698 doesn't.
http://waterheatertimer.org/GE-timers-and-manuals.html#57698
GE also makes 15077 digital power strip timer:
The digital power strip has Auto mode.
1) If programming has overlaps, or if programs are set for conflicting days, then timer will not operate as expected. Review programming steps by pressing PROG button.
2) If current time is not set, then programs will not operate. Press and HOLD clock button while setting current time.
3) I test timers, and sometimes manuals are confusing so I write out the steps to make sure I understand correctly.
4) It is possible that timer is defective.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | General Electric GE 24-Hour Power Strip...
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
238 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Craig Butler
Craig Butler
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
