Question about Lexmark C752 Printer
130 service fuser error
Lexmark C752 printer doesn't print and it's written on her that error.
    Problem Solver:
  • 5 Answers
This error generally points to a defective fuser assembly. If a new fuser has recently been installed, it could be the incorrect voltage for the printer. In addition, the line voltage into the printing environment could be sufficiently out of range or experiencing enough fluctuation to cause this error message to appear. Finally, the printer itself could be the incorrect voltage for its geographical location. Please go through the checklist below to determine the likely cause of the error and attempt a resolution for the issue.
  1. Power off the printer and unplug the power cord.
  2. Confirm the printer voltage by looking at the back of the machine where the power cord connects.
    • If the three-prong socket is white, the machine is 220V.
    • If the three-prong socket is black, the machine is 115V.
      NOTE: Generally speaking, North America uses 115V to 120V while Europe uses 220V to 230V. There are always exceptions for different areas, however, so try to verify that your printer's voltage corresponds to its geographical location.
      • If practical, have building maintenance check for proper line voltage.
  3. Check the voltage listed on the printer's information label.
  4. Check the fuser voltage by opening the fuser door on the lower right side of the machine. Look for the voltage details on the side of the fuser above the bar code.
  5. If the voltage checks for steps 2, 3, and 4 are consistent, go on to step 6.
    If there is a difference between the voltage indicated on the printer and the voltage indicated on the fuser, or if the printer's voltage is incorrect for its geographic location, contact Lexmark Technical Support.
  6. Re-seat the fuser to ensure that it is correctly and securely installed in the printer.
  7. If the voltage indicators are as expected and the fuser is installed correctly, plug the printer into another outlet (if practical) and power the printer back on to see if the error clears.
  8. If the error remains, contact Lexmark Technical Support for additional assistance. Please obtain the serial number of your printer before contacting Lexmark.
    NOTE: If possible, please call from near the printer as this will allow for the most accurate possible diagnosis.
Please rate it fixya if helpful.
Thank you
Posted on Feb 20, 2009
How to fix Lexmark T632 924 service Fuser error
924 is an open thermister error. The thermistor controls when power is actually applied to the heating lamp on the fuser. I used to have this problem with other Lexmark models and was able to replace the thermister itself. The thermister is located on the top cover of the fuser. If you have a real Radio Shack near you they should have them. I believe that the temperature should be around 400F.
May 08, 2015 | Lexmark T632 Laser Printer
How do I replace a fuser on a Lexmark C752?
por open right hand door drop lower door on fuser is two green leavers pull them to middle take old fuser out and replace the same way
Sep 21, 2011 | Lexmark C752 Printer
Lexmark C752 printer The printed image is blurred, looks like out of focus and the colors do not seem strong enough? any ideas ?
first check the toner level ? is it correct?
the blur can be caused by a dirty LASER UNIT remove all the cartridge clean properly the two laser unit.
if need another help i'm here and tell me me if your problem was resolved or not.
Oct 28, 2010 | Lexmark C752 Printer
Problems with the c760 900 service rip software error, can you help?
Perhaps this article on 900 Errors on a Lexmark C752, C760, or C762 will help. Just click on this link: There are embedded links on the page for additional info. If you need further assistance, don't hesitate to contact Lexmark technical support or your authorized service provider.
Sep 02, 2010 | Lexmark C760 Laser Printer
Lexmark X5150 All-in-One Error: 50
"When the printer fuser fails it prompts many HP laser printers to display an ERROR CODE 50 service code" same could be said about the lexmark fuser malfunction
replacining a fuser can be expensive might be better to get another printer unless you have a special bond like me i find it hard to just throw away things that have gone bad
Feb 01, 2010 | Lexmark X5150 All-In-One InkJet Printer
Lexmark C772n - 127.07 Service fuser error
I searched the Technical Manual and there is no explanation of the code. The user manual simply says there is a printer failure. They ask that you turn the printer off, wait 10 secs and then restart. Then call 1-800-LEXMARK and they will tell you about the code.
Given that your printer is saying Service Fuser, it is highly likely the fuser is ready for replacement. The fuser is the component that heats to high temperature to fuse the toner to the paper and complete the print cycle.
Aug 12, 2009 | Lexmark C762 Laser Printer
Lexmark C752
if you just run blank sheet through the printer using the printer feed button it should remove any ink on a roller. which probably got there from printing off a picture.
Apr 15, 2009 | Lexmark C752 Printer
Service printhead error 108
Error Code(s) Printhead Color
106, 111, 115, 171, 172 Cyan
107, 112, 116, 173, 174 Magenta
108, 113, 117, 175, 176 Yellow
109, 110, 114, 169, 170 Black
Power off the printer, take the Magenta cartridge out, take a lint and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. I just did it and it took me three minutes to clean with toilet paper rolled up like a cigarette.
My printer is back on line. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. This has happened to me before with a different color.
here is the Lexmark c750 support link:
I hope this helps. - This is from Joey V on fixyourownprinter dot com
Oct 13, 2008 | Lexmark C752 Printer
Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Jun 26, 2008 | Lexmark E342n Laser Printer
Lexmark c752
this unit has a scanner on top of the printer.It can scan fax print.I would like to clean the mirrors on the scanner on top of the machine
May 24, 2008 | Lexmark C752FN Printer
Lexmark C752 Printer Logo
456 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
