Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
My Toro S620 is hard to push & will not throw snow.
The paddles turn. The machine runs well
  • 2 more comments
  • nuhnuh1946 Jan 16, 2009
    This is a portable paddle type snow blower. I got new rubber blades today to repace the old. If they don't work, I will leave the question out there. One reply I received was to replace them. Thank you for asking.
  • nuhnuh1946 Jan 20, 2009
    The problem was fixed by replacing the old, shorter rubber paddles. If the longer paddles hit the scrape bar, I'd suggest removing some material from the bar & paddle. Thx
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello! well you fixed it good going and good smowblowing.dont forget to give rating.MrFixIt.
  • JERRY ABELL
    hello! could you be more clear on the type of machine;is it signal stage or double stage!
3 Suggested Answers
boscia
  • 163 Answers
SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Posted on Dec 13, 2008
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Posted on Dec 27, 2009
Motor runs paddle does not move
Your drive belt is probably broken or has slipped off. unplug your machine and turn it on its side (remove the pan and paddle first) and remove the bottom panel with a screwdriver. You will then be able to see if the belt is broken or has slipped off. You can reach me at breadmachineshelp.com for reinstall or replacement of your belt.
Jan 06, 2013 | Cuisinart CBK-200 Bread Maker
Hi there! I've been using my toastmaster model 1142 bread maker a lot lately like almost every day and it has stopped mixing the dough. Once the dough is dense the motor sounds like its running but the...
Pull the pan out and turn the little paddle with your finger. Is the paddle slipping on the spindle? If yes, then your paddle is worn out. If you move the paddle around and it doesn't slip on the spindle then look to see if the ears on the bottom of the pan are turning too when you move the paddle. If yes, then your problem is further down in the machine. You may have a slipping belt. Those are some of the things you can check.
Nov 07, 2010 | Toastmaster 1142 Bread Maker
Need a belt. do not have a parts list. does it take a belt? stopped turning but motor is running.
Hi. They sell the belts at Amazon for about $10.00. First you should make sure the paddle is not stuck. Take the bread pan out and see if you can turn the paddle by hand. Keep pan out of machine and start a kneading cycle. If motor shaft does not spin then it's probably the belt. Motor and belt is located in base of machine. Make sure you unplug the machine before checking out the belt. Hank
Aug 23, 2010 | Sunbeam 5891 Bread Maker
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
My breadmaker have two paddles,one seem like it doesnt have the power to turn porbable.what is wrong,i want to fit it myself.
Hi, This could be caused by 3 reasons. 1) The bearing on the paddle shaft is ready to fail and the paddle is sticking. Take the pan out of the machine and see if you can turn the paddle freely by hand. 2) The belt is slipping. Tighten up the belt in the machine. Belts and pulleys are in the base of the machine. Remember to unplug machine when you work on it. 3) Make sure the pan is seated properly in the machine. Good luck Hank
May 12, 2010 | Kitchen Appliances - Others
Drive shaft no longer turns kneading blade on model k6725
Either the paddle is frozen in the bread pan ( take pan & paddle out of machine and see if you can turn it by hand), or the belt has fallen off or has snapped. (Keep the bread pan out of the machine & run a knead cycle, look through the lid window and see if the motor shaft spins. Hank
Mar 05, 2010 | Regal Ware Kitchen Appliances - Others
Bread Machine not kneading
http://www.breadmakerguru.com/search.aspx?s=tr900
This site has bands/belts for breadmakers. I am buying my new paddle for the tr900s breadman pro from there. Perhaps your belt is broken? I personally have never replaced one, but it should not be too hard. Make sure you unplug the breadmaker before opening it up at all.
Try running the breadmaker with no pan in it and see if the paddle shaft turns at all during the cycle. Also, the paddle will not turn at all in the first 30 minutes of certain cycles, like the whole wheat. This is stated on the time chart of the instruction manual for this model.
Hope this helps!
WestHof
Apr 18, 2008 | Kitchen Appliances - Others
Paddle won't come out
I've had pretty good results with a crochet hook (use a metal one that can be run through your dishwasher). Insert the hook through the hole in the paddle and it should catch on the far side just enough to pull the paddle out of the loaf. Best to do it before it cools and the crust hardens, though.
Sep 23, 2006 | Black & Decker B1561 Bread Maker
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
415 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
