Question about Whirlpool GBD277PD Electric Double Oven
Have a Whirlpool Gold dbl. oven. Last Fri. night oven started beeping and display the E0F2 code. Turned off brk'r till next a.m., turned on only to have in a rolling sequence going from 350 upper oven on to 350 lwr. oven on to clean on. This is constant. If I hold down the off/cancel for 4-5 seconds, then a new code of E0 n0F2 displays. punch the OFF button again and the rolling cycle starts over. Both the Touch Panel and the Control board were replaced in April, 2011. Any suggestions
    Dedicated:
    Visited the website for 20 consecutive days.
  • Whirlpool Expert
  • 84 Answers
Good Evening!
Do you have the full model number of your appliance? Do all of the buttons beep when pressed? If not, unfortunately, the touchpad on your unit may have failed again. An E0-F2 is a stuck key error. The only way to fix this issue would be to replace your touchpad. Your more than welcome to send in your touchpad and control board for evaluation and testing. Contact us for more information info@fixyourboard.com. We also have replacement touchpads for your oven if the original OEM part is discontinued.
Ledgestone Technologies Keypad and Ribbon Cable Installation
Have a Whirlpool Gold dbl. oven. Last Fri. night o - fullsizerender 14-a2hfzyewnbytki35azudbdt4-2-0.jpg
Posted on Jun 06, 2017
  • 1314 Answers
SOURCE: Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
Posted on May 16, 2008
SOURCE: Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Posted on May 29, 2009
  • 142 Answers
SOURCE: Whirpool Accubake Control Panel
try turning power off and wait 10mins and see if it resets.
Posted on Sep 14, 2009
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Our Whirlpool oven started beeping
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#@!
Posted on Oct 01, 2010
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
My oven display is beeping and blinking 'PBR' on the display. What does that mean?
I had this same problem last night.. I have been having problems with the oven shutting off on preheat.. That sort of stopped. Last night lost power to the house. When it returned the oven was beeping and flashing PBR. I turned off the breaker for a few mins. last night and it returned. It was bugging me so much that turned it off the whole night. Woke up this morning turned the breaker back on and it stopped. I don't think this is the total solution. I am thinking that eventually I am going to have to replace power board in this oven. Hope it works!
Sep 23, 2009 | Jenn-Air Ovens
Sep 14, 2009 | Whirlpool RBD305PD Electric Double Oven
F-10 code and continuous beeping
Your board is going bad
Aug 25, 2009 | Ovens
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
Hello Edward!
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
asplogo.jpg?ver=23
appliance parts, help & more
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Display is black
I had a very similar problem (I was observing the error & fault code "E6 F2", but not always.  I did always have the beeps.) on a Whirlpool RBD305PDS14 double oven built-in.  I spent time today (Oct. 21) and traced the problem down to the keypad flexible cable that connects the keypad to the oven control panel.
[ALWAYS WORK WITH POWER OFF!!!]
I cleaned the flexible cable contacts that seat into the board mounted female connector on the control panel board using a Q tip and isoproply alcohol.  This did the trick.
(Elsewhere in this forum, there is information on how to remove the oven control panel and gain access to the control assembly.  I posted this information - keywords in subject: Whirlpool RBD305PDS14.)
Sep 25, 2007 | Whirlpool RBD305PD Electric Double Oven
Whirlpool GBD277PD Electric Double Oven Logo
52 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
