How to adjust a4 print margins on canon ir3225
How to adjust print margins
2 Suggested Answers
n00h
  • 624 Answers
SOURCE: i set A4 page margine
Hello and Welcome to FixYa!
You need to set the target margin from the formating software (Like MS.Word..etc) and from the Printer software as-well.
As far as the software is concerned, its under the page-setup, and for the printer its under the settings you got when the print dialog appears. For that Press Ctrl+P , the dialog will appear..at the top you will see your printer selected and after that a button like Settings, or preferences. Under that you will find the page setup settings, usually the Printer default is Letter not the A4. May be this is the issue.
Do tell me about the results.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Posted on Feb 18, 2011
Canon mg5200 printer is cutting off print from the left margin. How to fix?
You need to check the settings in the program you are using to print from. Check that paper size is set for the paper you are actually using. The usual culprit is A4 on program to Letter in the printer. Also check that Margins are set to Default.
Nov 04, 2016 | Canon Office Equipment & Supplies
I cannot get printer to print documents with equal margins.
Guess you are not using the same page size as the one you've got configured in your computer for printer. ie: you are using Letter and printer is configured to A4
Jul 18, 2015 | Dell Office Equipment & Supplies
How to fix NG in the log list of canon ir3225 that prevent it from printing document from pc
there was no code after NG.The print command is working from the pc but the canon machine ir3225 on the log list it shows the job no and all but in the result section it shows NG without any code.This Makes me headache ,please can any one solve this
May 23, 2014 | Canon imageRUNNER 3225 Black and White...
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
A few letters are cut off on left side
it could be a software problem. Please make sure that in the software where your printing originated, the paper size is set exactly as compared to the actual paper you use for printing. Example, if you are printing using an A4 paper, make sure that the document is laid out using the A4 setup with correct margins not exceeding the paper's printable area.
Nov 10, 2009 | Canon PIXMA MP470 All-in-One Printer
How can i adjust the settings on margins
No more paper-size error with [Scale-to-Fit A4] setting in the printer driver, or, select [Auto Size Detection] on the Printer device setting
Hope it works for you
Nov 03, 2009 | Canon LASER SHOT LBP-2900 Printer
Printing a full page 'background' (design) with no margins
No. The official minimum print margins are as follows
print margin specifications
Top (leading edge)
Bottom (trailing edge)1
Left
Right
Sheet Paper
U.S. letter
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. legal
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. executive
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
ISO A4
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
ISO A5
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
Sep 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
160 people viewed this question
k24674
jasbo
jasbo
