Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
Won't recognize external hd
  • SimpleTech Master
  • 27,725 Answers
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage Hope this helps.
Posted on Dec 13, 2012
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Computer won't recognize my simpletech 120 gb
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Posted on Oct 29, 2011
Computer won't recognize external usb hard drive
Format drive NTFS sounds like its corrupt, use mini partition wizard...
may also need 3TB Unlocker from manufacturer of Hdd
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Problem with Samsung G2 HM641JX 640Gb
You want to check if a the drive is recognized by windows, initialized and has a partition. Watch the video.
Dec 24, 2012 | Samsung S2 Portable HX MU010EA 1 TB...
Buffalo ministation hd-pct500u2 won't allow me access to it
Go Here
And you will have to download the CD image and then burn it on to a disk. This would possibly be why you can't see it in your device manager because it doesn't know what it's looking for and how to run it. by downloading, burning it, and then installing it. The computer will then know exactly what the peripheral is and how to recognize it and run it as a hard drive. I sure hope this has helped.
Thanks, Cody
Sep 13, 2012 | Buffalo Jeans Buffalo MiniStation...
Acomdata external hard drive not opening MBP
Acomdata Drive Not Recognized: I ran into the same issue. Actually the issue was with using an incorrect power adapter. It should be with power ratings of: Input 50-60 Hz 1.2A & Output 5V - 2A, 12V - 1.2A
Jun 22, 2012 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Problem with the Mobile Disk External Data Storage Enclosure model HD-338-COMP for my 80gb Western Digital HD
just a suggestion but a few years ago is aeons in tech time maybe, just maybe the drivers for that ext drive were overlapped with OS X migration?
check apple site for more or ext drive site for latest drivers
Jun 02, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My usb ports on my laptop only recognizes my phone and mp3 player and not my external hdd, it tells me to format the plug and play external hdd. It does not do this in all my usb ports though
Maybe the external hard drive is to large to be recognized by your computer. Some computers won't recognize real large external drives.
Another problem could be that your external hard drive does not support Windows 7.
May 20, 2012 | Acer Computers & Internet
Hi....my Samsung external HD G3 2tb won't turn on again after I erased all data on it. It is connected thru a hub to my iMac and taking off the power or USB and plugging back in won't do the t
It sounds like the drive has failed. The fact that you erased the drive just before it failed is coincidental.
Take the drive back and request a replacement under warranty. Also, demand that they destroy the drive in order to protect your data.
Feb 11, 2012 | Samsung Computers & Internet
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
Aiptek GSV 1080P HD Camcorder external mic feature won't work.
Possibly an impedance mis-match - check in both manuals.
Sep 27, 2017 | Video Cameras
External hard drive won't show files
If it behaves like this for multiple computers with multiple operating systems, I would think that the problem is with the hard drive or with how the files were stored. I would recommend trying a free recovery utility:
http://www.piriform.com/recuva
If this does not work, there are professionals who can do this service for you however it is generally expensive.
As a last ditch effort, boot your computer from a free Ubuntu CD (http://www.ubuntu.com/download/ubuntu/download) and see if it recognizes your files.
Dec 13, 2011 | Buffalo Technology Buffalo DriveStation...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
192 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
