Question about Toshiba 32AF44 32" TV
27 INCH PURE FLAT SCREEN POWER FAILURE
TURN IT ON IT'S FINE FOR 10 MINUTES. THEN, IT GOES OFF. WAIT A LITTLE WHILE AND YOU CAN TURN IT ON AGAIN. SAME THING HAPPENS OVER AND OVER. ANY IDEA?
    Problem Solver:
  • 9 Answers
MAY BE IT HAS COLD SOLDER IN POWER SUPPLY SECTION OR LOOK FOR A CRACK IN SOLDERED PIN PART OF EVERY COMPONENT PART IN THIS AREA AND RESOLDER IT.
Posted on Jun 13, 2007
Turn on TV and picture and sound are great for about 60 seconds. Then the picture disappears but sound remains.
I would start with checking the power supply 12vdc output, make sure it is stable with no ripple. If the power supply checks out fine, I would then suspect the main board.
Sep 20, 2012 | Vizio VT470M 47-inch 1080p 120Hz 5ms LCD...
When my 27 inch lcd with dvd is powered on, the screen pulsates fro 10 minutes then the flashing sound stops and all is fine
those akai flat panel tvs had several capacitors fail on the mainboard and the power supply board. you can see them vented on the top or bottom they will look like they are exploding.
Dec 23, 2010 | Akai LCT2715 27 in. LCD Television
My flat screen 12 inch sharp Tv has a black sqaure apparening when I change chennel or do anything with remote. It only goes away when pressing the vol. botton the a few minutes later show up again. please...
Your closed captioning mode is set to ON. You need to just turn that off. That setting is available through the on screen menu. Just turn closed captioning off and it will work normally again.
Apr 16, 2010 | Zenith C27A24T 27" TV
I have a 26 inch flat screen maxent and it works fine for about 10 minutes and then goes to a blue screen or a patterened screen and I have to shut it off for a while and then it will work again for about...
It sounds like heat relate problem or poor solder connections. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 18, 2009 | Televison & Video
Extremely long warm up time 25 minutes. ok once it comes on.
Just a shot in the dark- I think your main projection lamp is going bad- If the set is more than a year or 2 old it can happen. Unfortunately they are a little expensive.
How is the brightness level after it warms up??
May 30, 2009 | Audiovox FPE2706 27 in. LCD Television
Picture shows down the middle--both sides are black
may just need servicing, adjustment of the picture shape like parallel, etc service man can do it, its impossible for us to help.
or the high voltage is bad
Mar 29, 2009 | Akai LCT2715 27 in. LCD Television
13 inch rca true flat tv
if it is a straight thin line from left to right you have a vertical problem time to call service tech
Nov 29, 2007 | RCA TruFlat 27F520T 27" TV
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Toshiba 32AF44 32" TV Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
