I have acer aspire 5334. AC adapter plugged in but won't charge. Lights not showing on laptop and battery icon not showing its plugged in. Adapter rectangle box led light is on!! Is it charger, battery or problem with the laptop??
    Novelist:
    Champion:
  • 233 Answers
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
Posted on Dec 11, 2012
2 Suggested Answers
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Laptop not charging power & battery light flashes
Depending upon the age of your Acer laptop, it may be time for a battery replacement
Apr 19, 2013 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Acer aspire 5332 plugged in but not charging
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.If it doesn't work, the most likely cause is the laptop charger. Use a new one to confirm:
Replacement Acer Aspire 5332 AC Adapter 65Watt 19V 3.42A
Oct 23, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Acer aspire 5334.. battery says plugged in not charging
my note book is new,but battery says pluged in not charging,plz urgent help me.
Feb 09, 2011 | Acer Aspire 5241 5251 5332 5334 5338 5516...
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
Computers & Internet Logo
David Payne
David Payne
