JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv Logo
Galen C Nleosn Posted on Dec 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jvc hd56fn97 56-inch 1080p hdila rear projection tv with convergence problem, how do i fix this
Anonymous
Level 3:
Top Expert:
  • JVC Master 14,553 Answers
  • Posted on Dec 11, 2012
Anonymous
JVC Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2716352
Points
48227
That set cannot have a convergence problem as it has no convergence circuit, It is a DLP set with a lamp.
5 Related Answers
Vista Electronics
  • 1694 Answers
  • Posted on Nov 26, 2007
SOURCE: JCV HD Convergence Problem.
Replace both convergence IC's......Please confirm Model #
off back of TV and I will help you step-by-step....Requires
above-average soldering skill......................T.
A
Anonymous
  • Posted on May 11, 2008
SOURCE: cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
A
Anonymous
  • Posted on Aug 11, 2008
SOURCE: jvc projection tv
try this site http://www.sharefx.net/index.php
Anonymous
  • Posted on Jun 18, 2009
SOURCE: JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
Anonymous
  • 270 Answers
  • Posted on Jul 08, 2009
SOURCE: 52 inch jvc rear projection tv. Yesterday, came
send it to the survice center.
1helpful
I have a JVC flat screen tv that the picture is always dark on. I have tried all the menu settings including bright way up. Everything else works fine. Help ?
Sounds like you could have a burnt screen or something else the best way to be sure is to have it diagnosed by a I.T. pro or Tech.
https://www.6ya.com/mabtech386
JVC HD 56FN97 No RED color
Does menu have any red? Yes = digital video bad; No is light engine bad.
I had an amplifier hooked up and it went bad. discconnected it and now we have no sound. Went through the manual and changed the settings but still no sound, any suggestions?
recheck the cable connection, and use the multimeter for measure the continuity, and replace if necessary, clean for oxide, corrosion use the WD-40 and try again.
If the problem persis go to the repair shop TV.
2answers
No sound or picture
u need a new lamp and housing u can get it off of ebay.com from $35 to $90
Tv keeps shutting off
lamp might needs to be change if not check to see if cord is all the way in back of tv and wall
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
1helpful
2answers
2answers
JVC HD-52G786
you will need to have a tech come out to do a convergence( replace chips and resistors)they control the vertical , horizontal and color alignment
electech
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
