Question about Air Tools & Compressors
I have a Cummins 2 hp 13 gallon tank air compressor. I need to find a 90 degree elbow fitting that comes off the head for the air supply to go to the tank.
90 degree elbow fitting for air compressor head
  • 1314 Answers
SOURCE: Connecting the hot water line to a new dishwasher.
use teflon tape on the elbow if you did the back it off put some more on it and stop when its snugged facing the right direction now ive torqued them things pretty tight my self they don't strip that easy
Posted on Feb 16, 2008
  • 489 Answers
SOURCE: Hookup at water supply
I do believe so.  Check your installation guide for more info.  If you purchased a water line designed for dishwashers, it should have the 90º elbow included.
Posted on Apr 27, 2008
  • 1388 Answers
SOURCE: Air compressor head gasket diagram
Campbell hausfeld has all their manuals on line at www.chpower.com / you can enter the model # of the whole unit or just the # of the pump. Also you can enter just a partial number example wl650 for a list of models is that range. Use caution when installing gaskets for chpower oiless pumps. Some of their gaskets are very brittle. After installing parts, turn pump by hand to make sure all parts are in their proper place and that there is suction. Enjoy
Posted on Dec 02, 2008
csmock132
  • 4669 Answers
SOURCE: why can i only fit 13 gallons in my 19 gallon gas
You can usually only get about 18 gallons in a 19 gallon tank and you likely have 4 gallons left in it when the gauge reads empty
Posted on May 04, 2009
SOURCE: install reed valves hitachi air compressor need pics
I believe in your model of air compressor, when you take apart the head portion to your compressor you should have four reed valves. When you have it apart, there should be two "grooves" on the bottom "plate" and two "grooves" on the top plate (where the reed valves go). the bottom part is easy (as you should already know) to set in the reed valves, but as i have also found out, as you probably have, that its a little more difficult to line up the other reed valves to thier "grooves" on the upper "plate". What you do to make sure that they stay in place is dab a little oil or grease on the reeds and place them in the upper "plate grooves" and carefully set the upper plate back in place where it goes on the compressor. It will hold them in place long enough to install it on the compressor and the small amount of grease that was there will quickly be burned up with no effect to the opperation to the machine.
Sorry, long winded explanation. hope this helps and if it didnt get to you soon enough i hope it helps out in the future. :-D
Posted on Jul 10, 2009
Supply tub to tank
That is really not a hard part to find. You should be able to remove the broken one and take the whole tube into a hardware store and they can replace it for you. It should be a copper tubing with flare nuts on the ends. If not please post the model number of the compressor
Apr 27, 2013 | Magnum Air 2 HP 5 Gallon Twin Tank Air...
I have a Craftsman 3.5 hp, 25 gallon compressor. The compressor runs fine, but will not build pressure. Tank has pressure from the last cycle so I know it is not leaking. The compressor runs but no...
Hi Jim,
Disconnect your main air supply from the comp head to the receiver/tank and see if their is a reasonable air supply to atmosphere.
If not check that air is being taken in by the head intake filter
John
Aug 05, 2011 | Craftsman Air Tools & Compressors
I need a schematic Break down of a cummins 2hp 13 gal 115v 15 amp 13 gal tank air compressor Model # TD-5050(1204) Serial # 0702 including price for the electric motor Thank You
I have a TD-5050 13 gallon air compresser that is a 5 Horse running motor. The mmotor will not start on it's own with out me turning the motor by hand to get it started. I have to let all the air out and than spinn the motor to get it started. If I do this it will run for a long time. I think i might have messed it up with using too light of electric cord.
Aug 05, 2010 | Air Tools & Compressors
Compressor with head unloaders. Do I use a check valve with unloader port or a switch with a unloader on it?
Honestly you can use either. Some compressors come with both. My personal preference is the head mounted unloader valve because it's far more reliable and a lot less complicated.
However if you use a switch mounted unloader valve you can connect the tubing to either the head or the tank check valve.
Anywhere on the backside (between the check valve to the head), of the tank check valve is fine
Nov 14, 2009 | Northern Industrial 2 Hp 6 Gallons...
I want to cut 2 7/8 inch pipe to make a 90 degree elbow, not a corner but a sweeping corner. I know how to cut 2 45's to make a corner but I want the corner rounded.
They make pipe benders for you application. They are quite inexpensive. If you want to do it your self you can. Remember the total number of degrees you want is 90. Each cut is half the angle. Example 45+45=90. 30+30+30=90. and so forth.
I don't know your application but they sell larger radias 90 degree rigid conduit elbows at Home Depot or Lowes.
Apr 24, 2009 | Plumbing
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Air leakage through pressure switch needle
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
Feb 02, 2009 | Campbell Hausfeld 26 - Gallon Air...
Apr 02, 2008 | LG LDF8812 Stainless Steel Built-in...
Air Tools & Compressors Logo
107 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
