Question about Xerox WorkCentre 4150 Black and White Copier
How can we unlock the scanner xerox workcentre4150
    New Friend:
  • Xerox Expert
  • 118 Answers
Is this new or is it broken
Posted on Dec 23, 2012
I have a xerox workcentre PE120i that displays "scanner locked".how do i unlock it
There is a lock switch below the control panel. When the all-in-one is first shipped, there is a label that wraps over the switch and up to the control panel. When the label is gently pulled out, it moves the switch forward into the unlocked position.
The switch is below the area to the right of the frequently-dialed numbers short-cut buttons. To see a picture of the approximate location of the scanner lock, see page 2.3 of the MFP User Guide (this is page 29 of the PDF). The manual is available on the WorkCentre PE120/120i support page in the Documentation section: http://www.support.xerox.com/support/workcentre-pe120-pe120i/documentation/enus.html?operatingSystem=win10x64&fileLanguage=en . The direct link to the manual is currently http://www.support.xerox.com/support/workcentre-pe120-pe120i/file-redirect/enus.html?operatingSystem=win10x64&fileLanguage=en&contentId=53827 .
I hope this helps. If the scanner lock is in the unlocked position and you still get the error, then there is probably an internal problem. Whether this is a problem with the hardware or a sensor is unclear. If your unit is under warranty or covered by a service plan, contact Xerox or your printer/copier service provider.
Mar 28, 2018 | Xerox Office Equipment & Supplies
My Xerox 2400 Scanner is telling me it is locked but I have checked the switch and it is definitely in the unlocked position. I am also sing the correct power supply.I also uninstalled the software and...
Hello.
I am a Support Engineer with Xerox Scanners.
The scanner model that you have mentioned is very old. the description you have provided indicates that an internal component may have failed. I recommend calling our service department to discuss the replacement options available to you.
Please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Oct 08, 2012 | Xerox One Touch 2400 Flatbed Scanner
I have the message "Unlock scan head" when I turn the screw to the left to unlock it, I get the same message. Is there anything else I should be doing?
If you receive this error even after unlocking the scanhead xerox suggests replacing the scanner assembly. Item Inc offers this part on exchange for much cheaper then xerox. Here's a video to show you how to fix this error/replace the scanner.">
Aug 05, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Unlock scanner
under the scanner where you retrieve you printed papers on the left side twords the front there is a slide lever (which is the lock for the scanner).
Apr 29, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Iam trying to scan a document on my flatbed xerox 4800 but it keeps saying please unlock your scanner then it gives me time to do it but i dont know where to unlock it
you might have two program trying to use the scanner at the same time & the scanner is confused.Find out what programs you are using.Hint...even printer programs may use scanner drivers. 2nd.you MUST use the EXACT scanner driver for your scanner. Windows will see the scanner "locked out"
Jan 06, 2009 | Xerox One Touch 2400 Flatbed Scanner
Scanner locked. how to unlock
The scanner latch should be on the left side of the scanner.
You can try powering it off and on. Something is catching the scan head.
You should have a one year warranty on that product also if you need to call Xerox.
Feb 24, 2008 | Xerox WorkCentre 220 All-In-One Laser...
Xerox WorkCentre 4150 Black and White Copier Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
