Question about HTC S710 Smartphone
Htc s710 display black out
The display comes on turns off comes back on and turns off sometimes doesn't turn back on for days. i have done the resets and htc upgrade. please help.
  • Anonymous Jan 31, 2009
    One second i have a display the next it is black on my HTC710. I am going back to nokia
I have the same problem .... but my solution was to take the battery off and apply some presure on the are where that B (from Bluetooth) and that bin .... this solves the problem .... but just for a few minutes or days ..... depending on how much presure you apply.But be careful ..... too much presure and you will get in my situation .... crack the LCD :((
Posted on Oct 25, 2009
Well, even i had the same problem and after doing Cold Reboot and the Upgrade i finally went to my service centre.. and the guys told me that its a hardware problem..a connecting strip needs to be replaced .. if ur mobile is still within the warrantee period then they will do it free of cost otherwise it costs arnd 2500 INR
Posted on Feb 14, 2009
I had that problem for a long time, but found something on google. search for s710 backlight HKLM/ComtrolPanel/Power/Display  and change it to 30 or 60 or something in seconds.
 that worked on mine.
Posted on Feb 18, 2009
  • jondmac Feb 18, 2009
    change or make the registry key : HKCU//Control Panel/Power/Display back to 30 seconds.
    that solved it on mine.
How do i do that
Posted on Apr 23, 2010
How to make that registry key function bro will u pls explain in brief...?
Posted on Aug 27, 2009
  • 813 Answers
It seems to be some problem with the ribbon wire that connects the LCD lights to the main board, you will need to get the same replaced.
Posted on Oct 29, 2009
Ako neko ima displej za htc s710 da proda neka mi javi 0646168064
Posted on Sep 01, 2009
My htc s710 losing its screen line by line from the top turning to black
the cable flex is damage, replace the flex with the same..
that problem is common to all colored cell phones..
Jan 31, 2011 | HTC S710 Smartphone
My HTC_S710 screen blankin off
hard reset the phone...............
while switching the phone on press and hold both the softkeys....but u will loose all the data on phone. but will get rid of this problem. :)
plz do rate my solution thnks
Apr 03, 2009 | HTC S710 Smartphone
How to!!!!!
WAY: 1
* Open the 'Start' menu
* Select 'Expert'
* Select 'Clear Storage'
* You will now be prompted with a warning about the consequences of a hard reset.
WAY: 2
If you cannot run program to hard reset form "Expert" folder. Turn off your phone, then press both *SOFT KEYS* and *POWER ON* device. After moment release both soft keys. On the black screen asking for confirmation press *GREEN PHONE BUTTON* and wait couple minutes for phone to initialize.
Feb 05, 2009 | HTC S710 Smartphone
HTC S710 Smartphone not switching on
The battery is flat.
If the battery is very flat sometimes the phone will not start charging or turn on even when a power cable is connected.
This worked for me:
- Remove battery
- Insert power cable/usb cable
- Orange charge light should start flashing
- Re-insert battery
- Leave phone charge for a couple of hours
- Turn on
Feb 03, 2009 | HTC S710 Smartphone
Lgvx9400 screen turns black
I had the same problem. Went and bought a new battery.
Replaced it and let it charged without turning it off.
4 days now and I have not see the black screen yet.
Before it was happening almost everytime I wanted to use my phone.
At least once a hour I would have to shutdown and pull the battery.
Aug 30, 2008 | HTC S710 Smartphone
Screen turns black
This could the problem with corrupted software please get it reinstall , if the phone is under warranty get it done by the company or get it reinstalled in local mobile service center.........
Good luck...
Aug 01, 2008 | HTC S710 Smartphone
FREEZ
try to do a soft reset, that fixed my phones frezzing
Jul 03, 2008 | HTC S710 Smartphone
Screen problem
try to do a soft reset, that might work
Htc s710
very strange I would try a hard reset,
Backup your data as this will totally reset the phone.
There are two methods to performing a hard reset
  • Select Start > Accessories > Clear Storage. Enter 1234 where prompted and select YES.
  • Power the device off. Press and hold the left and right soft keys. Power the device on while holding these keys. Follow the on-screen prompts to factory reset the device.
If it fixes it maybe you installed some dodgy software, if it doesn't it sounds like a hardware problem
Best of luck
May 14, 2008 | HTC S710 Smartphone
HTC S710 Smartphone Logo
1,168 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
