Can i use RG6U with RCAs on each end for enterconnect on my parasound amp to my proseser,,,,, Thank you.
    Genius:
  • 1,175 Answers
No.
Posted on Jan 14, 2009
Parasound A51 have two channels out. The blue indicators in from of the amp did not turn on. The other three have blue lights when power is engaged. I opened the cover and measure each independent channel...
Whatever does the work in those channels has gone open circuit. This would not cause a fuse to blow, so power would be still present. I suspect it is the main amp chip(s) or transistor(s), which will be found on a heat sink.
Jan 07, 2018 | Parasound A 51 Amplifier
On my amp the protection light apperas when i hook the rcas up (red and white cables), i changed the leads looked at all the other leads eg power earth etc. do you have any ideas, many thanx wayne
turn down the amps gain and radio volume to lowest.
a. disconnect the RCAs at the source end. (at the head unit)
b. connect only 1 RCA at a time to the amp. ok?/fails?
still fails? u have a short in the RCA wire. toss it.
didnt fail?
a. with radio off, connect RCA to radio while RCAs are connected to amp.
fails? you've got a dead short on radio side.
does not fail? turn on radio...fails? radio is issue. (not very likely though)
my quess is that you've left out a significant observation as the probability of a shorted radio is low and you say you swapped RCAs.
May 08, 2011 | AudioBahn Car Audio & Video
Front Speakers Not Working
Hi, as a retired installer maybe i can suggest a better configuration. I would run your front speakers in series with your rear mids in low level. Your sound will be alot cleaner. Hppe that helps.
Aug 26, 2017 | Kenwood KDC-MP332 CD Player
I can not install the Philips RG6 quad shield compression connectors onto the Philips RG6U cable. There does not appear to be enough of an opening in the connector to allow the dielectric to fit. I need...
First, I did not have a projection tv problem. I had a problem with RG6U cable. I solved the problem by having a cable guy sell me some compression ends. No one from FixYa ever contacted me, so I took matters into my own hands. I'm sure I would have heard back if I subscribed to your service.
Won't use you again!
Nov 25, 2008 | Philips Televison & Video
Problems Overload Protection Being Invoked - Parasound HCA-2003
You may want to get an Ohm meter and check between the outputs of the amp yourself. 0 ohms means a short somewhere.
You should also check to se when you're hooking the speaker wires in that they're not frayed and touching hot to ground or hot to the amp casing. hope that helps!
Nov 18, 2008 | Audio Players & Recorders
Right side speakers don't work
if you are using RCAs as inputs to your amp.Swap the R to L @ RCAs to see if its comming in okay from radio.If both RCAs have audio then amp is bad ,If amp has any type of switches , move swithces to see if it comes back .Also if both RCAs inputs have audio .Move the RCAs when connected on amp to see if amp has bad connection in board to RCA jacks..If audio comes back on bad side when jack is moves .Then you have bad solder joints on board..If not then you must have bad outputs on amp..
Dec 22, 2007 | Car Audio & Video
Amp
if its the factory radio more likely it dont have RCAs ..You will need a 'speaker to line level adaptor" ..This has 3 or 4 wires at one end and RCAs at the other.simply connect a left and right set from behind radio or from rear speakers into left and right sets on adaptor ..then connect your RCA cables side to amplifier using RCA wires.
Dec 15, 2007 | Car Audio & Video
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
144 people viewed this question
 Grubhead
Grubhead
