Laptop w/ windows xp won't transmit sound to viewsonic wpg-150
We're a volunteer fire department and trying to setup a wireless connection to a projector using a WPG-150 router. We have no issues with video, but we do with audio. I've hooked up the audio out from the router to our surround sound using a 3.5mm to (2) RCA y adapter and a standard rca cable. We have no audio when we try to play things over the connection. The sound works fine if we disconnect from the router. laptop is a Dell D630 with XP SP2.
  • 2 more comments
  • Ranger302 Jan 14, 2009
    Viewsonic WPG-150. It's a wireless router for projectors that has power, LAN (in) for internet, VGA out to the projector and Audio out via a 3.5mm connection.
  • Ranger302 Jan 15, 2009
    Yep I tried a set of speakers at the router and got nothing. Plug them into the laptop and they work fine. Based on discussions with Viewsonic the issue is the laptop and something called a virtual audio cable or WDM. When I switched the audio output from speakers to this WDM I still get nothing out of the router and now nothing out of the laptop.
  • Ranger302 Jan 20, 2009
    Well I tired all the items noted to no avail so I called Dell for help. Needless to say at first they blamed Viewsonic for it not working and then she dropped a bompbshell stating the Latitude D630 can't transmit audio. I asked WHY it was installed and shows active and working properly with sounds and recording, yet it's not transmitting. She then proceeded to stat the video card within the laptop transmitted audio. I'm not the smartest regarding laptops but my BS meter was going off when she said that.
    So my question to those who have these virtual audio cables, what settings in XP are you using?
  • David
    David May 11, 2010
    What type of router is it?
    Problem Solver:
  • 13 Answers
Plug a set of head phones in to the WPG-150 Gateway and play something through the gateway. If you can hear it through the headphones you have a cable or stereo problem.
If you can't hear anything: On the sending computer, double click on the speaker icon in the system tray and make sure the volume is turned up on everything and nothing is 'muted.'
Posted on Jan 15, 2009
  • David
    David Jan 15, 2009
    Go to the control panel and then 'Sounds and Audio Devices. Click the tab that says Audio. Check the settings under 'Sound Playback.' Try changing to different devices and also check the Volume button for each device.
Problems with Acer laptop running XP, can only get wirless access if there is no wireless password
Chances are that it is still remembering an old password somewhere in the properties... dig through the options an properties to see if there is a place to enter a password that may be overriding the one you are entering when you try to connect.
I know it sounds wrong, but I've run into this before on Windows 7 laptops and have found a previous password embedded in the properties that (once the correct password is entered there) solves the problem.
Nov 01, 2017 | D-Link Wireless N 150 Home Router
Belkin n750 db connects with windows 7 laptop, but will not connect with xp laptop. It will not let me enter the password.
It is possible that, if you have the router set to wireless N only, your XP machine won't interact with it. Your XP adapter probably doesn't support wireless "N"--you'll have to tell the router to use "N" or "G"
Apr 21, 2012 | Belkin N750 DB Wireless Dual Band N Router
I have installed a N150 Wireless adaptor DWA-525 to my desktop XP, and entered the pin etc to start the connection. However the adator is in a endless loop trying to 'Acquire a Network Address'....
go over to the bottom of the where the clock is on taskbar pace the mouse over the the little computer it shows what does it say exactly?
if its still searching right click and hit repair. If that dosent work then right click again and click on view wireless connections
Jun 23, 2011 | D-Link DWA-525 IEEE 802.11n (draft) -...
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
How to connect wifi with acer laptop
Any wireless router will work. You just have to find the router’s signal on your computer (and sign in to the network potentially).
Your laptop should have a built in wireless card. If it doesn’t, you won’t be able to wirelessly use the internet until you do. I’m assuming you are using Windows.
Click Start at the bottom of the screen, the open your Control Panel. Select the category Network and Internet Connections.
There should be a wireless network setup wizard in there, and will help guide you through the process of setting everything up.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 19, 2009 | Microsoft Windows XP Home Edition with...
My HP laptop won't connect to my NETGEAR WGR614v7 router
What is your operating system (Vista/XP, older Windows)? Have you turned on the router's wireless router radio from the computer that is connecting? (Login to the router's setup page at 192.168.1.1 or 192.168.0.1 (depending on the router) and go to Advanced menu and click Wireless Settings.) While you are there, enable the SSID Broadcast (another checkbox hust below the one for Wireless Router Radio). Now check if your laptop can see the router.
Additional FAQs that might be helpful are at http://kb.netgear.com/app/products/model/a_id/2589. That page has a link to setting up XP for wireless networking as well.
Aug 11, 2009 | NetGear WGR614 Wireless Router
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Just purchased laptop with windows vista home premium
If your PC has a wireless card, you can setup an AD-HOC network :
If your PC is XP: http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
If your PC is Vista: http://windowshelp.microsoft.com/windows/en-us/help/293c504f-b944-4d5d-835c-f080129bd5dc1033.mspx
If your PC only has a wired Ethernet connection, you may still connect the two using a Wireless Access Point/Router.
Once you have the two computers connected, you may do whatever networked operations you would like:
File & Printer Sharing is the most common:
XP: http://www.wellesley.edu/Computing/FileSharing/Windows/win2kxp.html
Vista: http://www.windowsnetworking.com/articles_tutorials/File-Print-Sharing-Windows-Vista.html
Aug 01, 2008 | Apple iPhone 3G
About wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Feb 10, 2008 | Computers & Internet
Computers & Internet Logo
292 people viewed this question
David Payne
David Payne
