Question about Broan-NuTone Kitchen Ranges
How do I remove broan QS1 fan blade - Broan-NuTone Kitchen Ranges
Theres a round clip you have to pry off (its silver but first you remove the the cotter pin looking clip that just slides out)..took me a few to figure it out but its a pain to remove ..use a small flat screwdriver and you will get it off eventually..then when reinstalling you have to press it in while lifting the clip with again a small flat screwdriver.
Posted on May 25, 2018
2 Suggested Answers
  • 491 Answers
SOURCE: The fan blade of new Broan range hood is woobling
check bolt holding fan is tight
Posted on Oct 10, 2009
Testimonial: "His quick and very helpful answers decided me do not return the unit to the store and to begin the installation. Thanks again!"
How do i remove the blower wheel from a broan 684 bath fan
There are a number of YouTube videos that show how to replace the motor assembly on a Broan bath fan. Once you have unplugged the fan and removed the motor mounting plate you will have easy access to replace the blower wheel and/or the motor assembly.
Just go to You Tube and search on Broan
Sep 16, 2014 | Broan-NuTone Dryers
I installed a new Broan QML30SS range hood and fan makes loud humming sound as it runs
An old elecricians joke says "do you know why it hums? It dosn't know the words" Al kidding aside ,have you checked to see how free the fan blade is? The should spin very freely. It kind of sounds to me like it may be having a hard time comming up to full speed. You may try some graphite lube on the motor. If I recall Broan has a lifetime garrentee on the motor. You might just want to repace it if I am correct.
Mar 02, 2013 | Broan QML30SS Pro-Style Under-Cabinet...
My bathroom Broan exhast w/light makes a constant clicking / tick tock sort of noise when the fan is not running. as soon as I turn the fan on the noise stops and then stops after I turn the fan off, only...
remove the cover and clean anything in the vent , check the fan for anything that could be touching it, as the back draft comes through the vent, something could just be touching the fan blade as this draft makes the blade turn slowly, which would create a ticking noise
Jul 10, 2011 | Broan-NuTone (8663RP) Ceiling Fan
How to remove grease from fan 'blades' withut removing motor
the fan should come right off. they screw on,- or they have a set screw,- or they have a clip,- or sometimes if they are plastic they just pull off. this is all assuming that you can get to the fan.
Oct 09, 2010 | Broan-NuTone Allure QS130SS Kitchen Hood
My fan doesn't start right away when the switch is turned on. Then as it is starting up it squeaks and hesitates. Seems like a "gunked-up" problem but I can't remove the impeller blade assembly from the...
The fan blade can be removed from the shaft. You just need to pop the lock washer off and pry the fan blade. You most likely will not be able to remove the fan blade without damaging the blade. You can buy the replacement fan blades online. The part number is 5901A000. Here is a blog on the entire replacement motor assembly. http://nutoneproducts.typepad.com/nutone-products/2009/08/nutone-0695b000-replacement-bath-fan-motor-for-model-qt80.html
Oct 05, 2009 | Broan-NuTone QT80 Fan
Hi. my vent made some funny noises last week and
Check the fan blades and see if it's being restricted.Another method is remove the fan blade turn the unit on and see if it spins if it doen'nt tap the motor gently and see if turns.If this works the motor brushes are worn
Sep 28, 2009 | Broan-NuTone N-QT100FL Combination Light...
Vibration at high speed
check these causes fan blade brackets,fan blade for cracks, any grease on blades.
Dec 27, 2007 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Kitchen Ranges Logo
282 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
