Question about Radio Communications
Motorola DCX3200-M beeping after rehooking
Beeping after I hooked up my cable box again.. Coming from the cable box via my television. Please help.
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Russell,
Your query has been posted on the 2-way radio forum.
please post on the TV forum on this site.
Regards, Peter
Posted on Mar 07, 2013
We just set up our Lorex LHV1000 8 channel system but the dvr won't stop beeping. How do I make it stop? We only have 4 cameras in use but we tried plugging all 8 in to see if that was the problem but it...
Might be too late... but it beeps if its not hooked up to internet. So to stop it from beeping either connect it to ethernet cable in back, or you can turn off beeping in menus- its i believe settings, event, network- then unclick the box thats there
Mar 13, 2015 | Lorex Home Security
There is a beeping sound coming from the mother board
The beeps are error codes. The hard uses a grey or blue ribbon cable and one power connector from motherboard.
Oct 08, 2012 | VIA A7vbx-la Socket A / 462 Amd...
I have a JVC HR-XVC1U to a Panasonic Viera TV, via a Motorola DCX3200 how do I get to record any VHS Tapes
First, you can not record digitial to VHS tapes if you are planning to record from the TV. Second, you can hook them up through the RCA cables.
May 30, 2011 | YouTube Videos
I have an RCA rear Projection TV model # p60812BL manufactured in 1998, no sound is coming from the tv when watching cable TV via a digital box. When the mute button is pressed and unpressed you can hear...
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
Mar 16, 2011 | RCA P52926 52" Rear Projection Television
Hi, I have a problem finding a code for my motorola DCX3200 with my universal remote control(cox.) All the other televisions in the house worked, but I can't get this one to respond at all. I have an LCD...
Here is the user guide for the Motorola DCX3200 in PDF format just in case you need it.
Now then here are some Codes for your Cox Universal remote. I understand you have tried some already but just in case you missed any.
Samsung 0060, 0030, 0178, 0019, 0056, 0032
Also give this a try.
  1. Turn on the TV, VCR, DVD, or entertainment center that you want the remote control to control.
  2. On the remote control, press the appropriate mode button for the device once.
    Television TV
    Stereo amplifier or receiver AUX
    DVD, PVR, VCR DVD
  3. Press and hold the SETUP button until the selected mode button blinks twice, then release the SETUP button.
  4. Using the number keys, enter 9 - 9 - 1.
    Result: The selected mode button blinks twice.
  5. Aim the remote control at the device, and then press the POWER button once.
  6. Press the CH+ (or CH-) button one or more times until the device turns off.
    Notes:
    In search mode, the remote control sends IR codes from its library to the selected device, starting with the most popular code first.
    If, while pressing the CH+ button, you inadvertently pass the code, press the CH- button one or more times until the TV turns on.
  7. Press the SETUP button once to lock in the code.
  8. To search for codes for other devices, repeat steps 1 through 7.
Hope this helps, give me thumbs please!
Aug 23, 2010 | Televison & Video
Digital Audio cutting out
I have the same problem with my RX-V565 receiver. Did you get this fixed?
Albert
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
Jan 10, 2009 | Toshiba 50HP66 50 in. Plasma Television
No signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Dec 11, 2008 | Polaroid FLM-323B Television
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
Please help
Could also be the cable, set are now designed if no signal to shutdown, so first check media box by calling cable company and or replace and try another just to make sure.
Aug 27, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Radio Communications Logo
56 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
