Broken sony remote RM ANU005 - where can I buy an original replacement?
Anyone know where I can source an original RM ANU005 to replace?
SOURCE: sony rm-v310 universal remote code
Try this link from Sony
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV310
Posted on Jul 23, 2009
SOURCE: How to open remote control Sony RM-Y181
I had open a Sony RM-GA010 because the transmitting bulb was stucked inside after a fall. The two screws inside the battery compartment was not really holding the case together. I used two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous. You need to accept some permanent depression at the edge of the control (better than a useless remote). Once you open some part, it become much more easy. After opening the outer case, you can access the buttons, but not he transmitting bulb in my case. I need to loosen two additional screws (i.e. totally four, including the two inside the battery compartment) to loosen the electronic board a bit and I could correct the bended transmitting bulb. Then put everything back, clicked up the case and the remote worked again!
Ben
Posted on Aug 29, 2009
  • 19 Answers
SOURCE: Code for Sony RM-V310A remote.
try going to and plug in the information there and see what you get
http://www.oneforall.co.uk/us_US/support
  • 4 Answers
SOURCE: Replacement Sony RM ED009 remote not working
Remote sensor on the tv may not be working. Try using a camera by aiming the remote IR sensor of the remote control at the camera lens then press and hole any button and check if you see a flicker of light. If you do, the remote control is transmitting, if not, the remote control is not working. This will tell you if the remote sensor on the tv is not getting the signal from the remote control
Posted on Dec 08, 2010
gopakumarg43
  • 75283 Answers
SOURCE: My remote for Olevia 32"
Hello
Chunchop remote has no setup codes with Olivia TV. Just buy one RCA RCR312W remote control. It has codes for Olivia, and most of the other TVs at present. You will get its maual with codes and proceedings about how to setup and synchronise it with your Olivia Tv.
The codes for Olivia with this remote control are:
11610, 11144, 11240, 11331
OK.
Posted on Sep 18, 2011
Testimonial: "thank you very much! i have to search for this RCA Remote here in my area now....."
Sony rm ss251
As all other buttons works properly except Volum Dn, the problem is with the remote control itself. Clean the remote control and check. To clean it, you have to open the remote control. If it too doesn't help you, buy one original remote control from the authorized service center for Sony. No universal remote control will go properly with Sony TVs. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Sony Televison & Video
Only my source button works on my sony cdxgt340 car stereo
I have the same problem, but find out that someones remote works. I find an original remote RM X151 on eBay for $4.00
And this works !!!! I guess a lot of Sony owners have the same problem, but if you would like a quick fix without going very expensive, you can just buy this remote and hope will work as well for you. Good luck.
Nov 22, 2013 | Sony Xpl?d CDXGT340
Alright, so is there any way I can get the Sony RM-V310 remote to work with a dish network reciever
probably not. you need the original dish network receiver remote. call your Dish provider for a replacement.
Jul 22, 2010 | Sony RM-V310 Remote Control
Remote does not work, tv is fine
Found universal replacement remote for Viewsonic N2750 at Target for $15. Works perfectly. it's the Sony RM-V310A. Tried all 5 remotes from Walmart, none worked even though it said would work on back of packaging..Target has about 5 Remotes only this one worked. My original remote died after 2 years. ordered an original replacement. that one died after 2 years. They're ****.Manufacturer discontinued it. found one online for $50. Just get the Sony RM-V310A at target.
Oct 14, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Certain buttons wont respond
I had a Sony remote that got dropped. Looked inside and found the circuit board broken. The ideal solution is to by a direct replacement--expensive. I had an amplifier remote with learning and lots of buttons. The cheapest ($10-$15) is to buy a universal remote, hopefully with a learning function in case you need to get more that just the numbers, volume, mute, and up/down. They may not know how to change source, TV/VCR, menu, etc. Most will know how to do Sony while many will not know off brands. -Ken
Aug 29, 2009 | Sony RM-Y173 Remote Control
Toshiba 40H80 TV - looking for original remote.
You can buy them at any of these sites:
http://www.toshiba.newremotecontrol.com/catalog_item.php?catnum=23306458
http://www.remotes.com/store/toshiba/40h80.html
or ebay
Aug 17, 2009 | Televison & Video
Sony universal remote will not operate sony dream system
Solution is to buy Sony original remote for DAV-FR10W system from Sony Accessories Store under following part number..
147869811 RM-SP350 REMOTE CONTROL
Feb 05, 2009 | Sony DAV-FR10W System
Sony RM-Y168 remote needs VCR codes for Zenith brand
code for zenith vcr is 331 if your remote is rm y168.
Nov 23, 2008 | Sony RM-Y168 Remote Control
Sony rmav2100t
you prob is the LCD actually if you can open it up and look for the small piece of info ( partnumber) at the back side of the lcd it can help you but the lcd al,one and replace this by yourself, google the part numer or search the web for LCD parts usually this things are quite available in the market,
cheers
Oct 12, 2008 | Sony RM-AV2100 LCD Touchscreen Remote...
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
