Question about Texas Instruments TI-85 Calculator
TI-85 Calculator's LCD Display if faded
I bought my TI-85 in 1995. I have not used it in several years. I just refreshed the batteries and noticed that the LCD display is faded I can't see anything but a faded blip on the display, so I know that it is on. I remember that back in the days I used to press the blue button and the UP arrow and that used to brighten up the LCD display, however that does not do anything to fix this problem. PLEASE ADVICE WHAT TO DO. Thank you!
  • Javier Medina
    Javier Medina Jan 13, 2009
    I did a little research on the Texas Instruments Website  and here is the answer.
    Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
    http://epsstore.ti.com/OA_HTML/csksxvm.j...
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=85103&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG57C2FA762C0BEC303F5B74A9018844AE124A5516274A019AFE22BA90B20
Posted on Jan 14, 2009
Ti 85 wont turn on, batts good, tried to adj contrast , still nothing
Are you sure the batteries are in correctly? They alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. You tried adjusting the contrast. Just try adjusting upwards. Sometimes it takes a little for The Ti 85 to come on or adjust right. The Ti85 is an old calculator and, may not work any more. I had my Ti89 for almost 20 years so, they are pretty reliable. If nothing has worked take out all the batteries including the small one in the back. Texas Instruments say's " leave them out for 5 to 10 minutes." I had to leave mine out for over a 1/2 day to get it to work.
Here is the battery reset procedure for the Ti 85.
Try a new set of AAA batteries.
  1. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the
    AAA battery and then turn the calculator on.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute
  4. period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Just keep trying. Sometimes they can be a pain.
Dec 28, 2010 | Texas Instruments TI-85 Calculator
I have not used my TI-85 in 8 years. Inow it will not turn on. I put in fresh batteries. I stored it without batteries in it.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Jun 30, 2010 | Texas Instruments TI-85 Calculator
My TI-85 will not come on
Screen contrast problem. When the calculator lost power the contrast was reset to zero.
If new batteries, both AAA and Memory battery CR 1616, then press ON, then 2nd (yellow
Key), then UP arrow, More UP arrow if desired contrast is needed more. You should see the
display or screen effectively. It is not that it would not turn on, it was just that you couldn't
see the display, it was set too low for observation............................It was on just couldn't see it.......
Mar 26, 2009 | Texas Instruments TI-85 Calculator
TI-83 PLUS
Most likely your battery is dying.
You can replace by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA from Amazon, Staples or elsewhere.
I've used TI-30XA's for years, batteries usually last 2-3 years, then I buy new calculator. The one time I tried to replace battery, fading display still problem, so circuit board had gone bad.
So you could try battery replace and may be OK, but also may be waste of time and $$
Nov 06, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Problem
Either battery is dying, or circuit board has gone, or connector cable loose.
You can replace battery by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA for $10 from Amazon, Staples or elsewhere.
Nov 04, 2008 | Texas Instruments TI-30XA Calculator
TI-85 Display Has Missing Lines
have u ever modded it? it can (and probably will)damage the screen (graphics driver)
Oct 26, 2007 | Texas Instruments TI-85 Calculator
No image display on screen
heres a good one: BUY A NEW ONE!!!!!!
(i dunno)
Oct 16, 2007 | Texas Instruments TI-85 Calculator
Texas Instruments TI-85 Calculator Logo
1,882 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
