Question about Pioneer GM-5300T Car Audio Amplifier
Amp just abruptly stopped working (Pioneer GM-5300T)
I just installed a Pioneer GM-5300T amp in my girlfriend's car (1999 Pontiac Sunfire). When I completed the installation everything worked properly (i.e., sound was coming from the subwoofers). However, as my girlfriend was driving back home, the sound abruptly stopped emitting from the subs (she had been driving approximately 30 minutes when it happened). I checked all of the fuses (they were fine), all of the connections were tight (including the ground), the speakers did not appear to be blown, the power wire was not crimped or severed. I noticed that the power indicator was lit, so power appeared to be feeding to the amp. Honestly, I'm stumped...I don't know what is wrong. I mounted the amp on top of the speaker box. I grounded the amp to a metal plate extending down from the top of trunk ceiling (not the trunk lid!) - I made sure to scrape the paint away from the metal for a good ground. The only concern I had was the in routing the power wire, I had to run it fairly close to where the exhaust pipe connects to the exhaust manifold (it was about 3 inches away from the pipe), however, I covered the power wire with a wire loom to protect it from heat. Like I said, everything worked just fine when I hooked it up, and it worked for about 30 minutes as she was driving home, then the sound just stopped coming from the subs. Any help, guidance, and/or solutions would be GREATLY appreciated. Please email me with any suggestions.
  • jwright1622 Mar 10, 2009
    My amp was working just fine for about a week and then nothing power light is on nothing wrong with wiring and the sub is a pioneer sub so ohms are not to low. So now what do I do, I did smell something after it happened but amp did not seem to be that hot checked all wireing at that point all of them were in tact. I do have a fuse on the power line, haven't checked the internal fuses, but wouldnt the power light be off if one of these fuses were blown. Hole system is pioneer head unit is dehp-4000ub and door and sub speakers are also pioneer dont remember sub or door speaker model numbers but I do know what sub wattage is 800 and it is a 12. Cant really look at sub thogh since box is completley sealed. so know what do I do
    Problem Solver:
  • 10 Answers
Apart from the external DC power fuse (I hope you have one in-line), the majority of in-car amps have 2 mini fuses inside the unit to protect the output MOSFETs from overloading due to incorrect speaker connections, ie, if the output impedence is rated at 4ohms, anything less than that is considered to be a short circuit, and will overload the MOSFETs. After performing the tests suggested by KaeZoo, open the unit and look for printed markings on the circuit board, something like F1, F2, the fuses may not look like conventional fuses.
Posted on Jun 12, 2007
  • 156 Answers
You'll need a digital multimeter to do any real troubleshooting. There are two tests you should try that might help you find the problem. First, while the system is playing, test for DC volts at the ground and positive power terminals on the amp. Place the black probe on the amp's ground terminal and the red probe on the B+ terminal. You should get a reading of around 12 volts or more. If you get a much lower reading, then try replacing the main power fuse at the battery. Some fuses, especially AGU (glass tube) type, can fail even if they don't look blown. The next test is to disconnect the speaker wires from the amp and test the resistance through the speakers. If a subwoofer has a damaged voice coil, it won't be apparent from inspecting the sub. You might find an open coil (no continuity through the subwoofer) or a shorted coil (close to 0 resistance through the subwoofer). In either case the sound will stop. If you find one of these, check inside the sub box to make sure it's not just a loose wire.
Posted on Jun 11, 2007
Wiring
you have the remto wire hook up it blue from deck to amp?
Jul 07, 2013 | Pioneer GM-5300T Car Audio Amplifier
My pioneer gm 5300t amp cuts off at loud volume and will not kick back on until it is turned down and cools off, what is wrong with it?
You are over heating it,You have your speakers wired up for a lower,(OHM) Rate then the amp can handle, That why it cut out when you have it turn up
Nov 10, 2012 | Pioneer GM-5300T Car Audio Amplifier
Hi, I installed my system myself and I'm having trouble with my Pioneer GM-5300t getting really hot. I'm trying to find out what might cause this. Could it be that I have a bad ground or I have the...
it could be the wires from ur sub to the outside box ,like on the inside of the speaker box ,power an ground should be the same but not always. if its new it sometimes mite have a smell .
Jun 03, 2011 | Pioneer GM-5300T Car Audio Amplifier
Are subfoofer ts-w308d2 and amplifier GM-5300T compatible with each other?
Yes. You will be able to run this setup with the sub bridged across both channels of the amp, which will give you more power (which the sub will be able to handle: 380 watts rms), or with the sub wired to a single channel, which will give you less power (125 watts rms). The sub can handle 400 watts rms.
Mar 18, 2011 | Pioneer GM-5300T Car Audio Amplifier
I parelled one 15" q power subwoofer to my brideged pioneer amp.The amp got really hot and blew a fuse.How should I wire my dvc subwoofer to the briged amp.
Hello sir, hi, YOU DON'T bridge no more speakers, this upsets the impedance load of the amp. to install another sub-woofer, get another amplifier. You may have damaged your power amplifier, If you experience repeated fuse blows, your power amplifier is now SHORTED. This needs IC amplifier replacement.
Aug 19, 2010 | Pioneer GM-5300T Car Audio Amplifier
I have a pioneer 760watt model gm5100t amp and two audiobahn 12" subs and I would like to know how the wiring is configured from the amp to the subs as well as how the subs are wired since they are dual...
you bridge the inside + - and use the outside + -
then connect the outside + to the amp then connect the - to the + on the other sub then the - on the other sub to the amp just read this and do it slowly and you will get it then you only have to run the subs on a two channel amp
rate pls
Aug 14, 2010 | Pioneer GM-5300T Car Audio Amplifier
My amp normaly has a continuious blue light when functioninng properley now it is at a fast blink and my subs wont work what is the problem i have checked the hot and ground and the remote wire .if i...
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Feb 01, 2010 | Pioneer GM-5300T Car Audio Amplifier
I have a Pioneer GM-5300T amp wired to a 10 inch kicker sub. The music plays throughout the speakers of my car but the sub goes in and out. I noticed that the amp's power light dims when the sub goes in...
Hello pburgfootbal,
You do not specify which Kicker sub you have or how it is wired to the amp. The GM-5300T is only stable to 4ohms in bridged mode and if your sub is a 4ohm DVC with the coils in parallel, it presents a 2ohm load. If the sub is 2ohm DVC with the coils in parallel, the load is only 1ohm. Either configuration would be too low of an impedance for the amp in bridged mode. I'd check the sub specifications and make sure that the wiring configuration properly matches it to the amp.
Hope this helps.
Jul 31, 2009 | Pioneer GM-5300T Car Audio Amplifier
What does the system control wire get hooked up tooo??????
it's just a remote wire it goes from your amp to the car stereo. usually on the wire harness for your cd player the color is BLUE but it should be labeled.
Mar 10, 2009 | Pioneer GM-5300T Car Audio Amplifier
Pioneer GM-5300T Car Audio Amplifier Logo
776 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
