Question about Echo Cs3000
Hi I have an echo CS-3000 and the throttle linkage keeps falling off. I've opened the aircleaner and hooked the rod back up to the carb and it falls off again. Is there a clip or something i'm missing? Maybe it needs to be bent a certain way?
dontbother10
  • 2220 Answers
SOURCE: How do I change the primer bulb on my Echo CS-3000
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Posted on Sep 07, 2009
Testimonial: "Having the parts list helped me to understand how the primer bulb was installed. A great help. Thanks, Ed"
dontbother10
  • 2220 Answers
SOURCE: dropped my echo cs-3000 ignition coil wires came
EchoUSA
http://www.echo-usa.com/faqs.asp
#2,
then line 2 "Operator's Manuals/Parts Catalogs/etc."
Click "CS3000"
Toward the botom is the "Parts Catalog", choose the "Ignition, Starter Assembly" detail.
Item 4 connects between the coil and the on/off switch.
HTH
Lou
Posted on Nov 19, 2009
dontbother10
  • 2220 Answers
SOURCE: i have an echo chainsaw cs 346 it starts fine revs
Try rotating the "H" adjustment CCW a small amount.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Posted on Jan 11, 2010
  • 4088 Answers
SOURCE: ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Posted on Apr 29, 2010
  • 277 Answers
SOURCE: how do I replace the purge pump on thr Echo chain
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Posted on Jun 21, 2010
Olds 88 turns over has gas will not fire
Check for loss of spark first.
Jun 02, 2017 | Cars & Trucks
How to install a throttle cable on an ECHO PB-251 blower
throttle cable ??? should actually have a throttle rod that goes to a very short piece of cable. and this cable only goes from the carb to the throttle rod. the cable is actually easy to replace. it's only 3 inches long. the throttle rod or trigger requires removal of one side of the handle.
Oct 19, 2014 | ECHO, Inc. PB-251C Handheld Blower
99 Chrysler Town and Country idles high
Maybe a sticking choke or binding throttle linkage. Have you lifted the aircleaner cover and looked down carb opening? Choke stuck?
Could be a simple idle speed adjustment also. What rpm's do consider to be high. Maybe some carb cleaner down the barrels and throttle linkage could free it up. Again, it could be a simple idle adjustment depending on RPM's it's turning.
Apr 05, 2013 | Chrysler Town and Country Cars & Trucks
I need a diagram for the path of the inner throrrle cable.
throttle cable goes around the metal guide and then under the wire loop and then push the ball up into loop, try your throttle to make sure it doesn't bind when it's hooked up... the cable will ride on the little round cover (metal) then set in the u in the rod from trigger. long as it moves freely and has the carb range , it's good
Aug 21, 2011 | ECHO, Inc. PB-251C Handheld Blower
Homelite d630cd weedeater. the throttle line came unhinged where it attaches to the carbereutor so when I give it gas with the lever it does not open the carbereutor. how do I re-attache the line?
It is usually not very easy to reattach such a line because there are bends in the rod which are designed to keep the bar from falling out (as happened in your case). The engineering varies from saw to saw, however, removal of the throttle lever on the hand side is usually necessary.
When it has been removed, it can be removed from the rod. The other end may be turned into the carb connecter. And then the button turned back into the rod and installed back into the handle.
As you fix it, you might wish to tweak a bend so that it won't fall off again.
:o).
Jun 04, 2011 | Garden
I have an Echo CS-3450 model... The throttle trigger has become disengaged somehow. When I depress it, no reaction from the engine or bar. Any ideas how to fix it?
the trigger is connected to the carb with a linkage rod. it has probably come off. usually you will need to disassemble the saw to get to it. not a easy job. some times best to take it to a shop
Feb 12, 2011 | Echo Garden
Idle to high
Make sure the carburetor was re-installed correctly as any air leak between the carburetor and cylinder will cause high engine speeds but almost no power. It can also scuff the piston/ring(s) and cylinder due to very lean lubrication from the fuel. Hope this helps!
Jul 12, 2010 | Echo CS400 18" Chain Saw
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do I change the primer bulb on my Echo CS-3000 chain saw
Lou
Sep 06, 2009 | Echo Garden
Echo Cs3000 Logo
67 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
