Question about Acer Aspire L100 PC Desktop
No sound hi there, can someone help me. i have a Acer Aspire L100 i was watching vidoes in youtube and i was unpluging mic by accident i unpluged the speakers. I pluged the speakers again was no sound check by control panel everything is ok checked the vulum there everything is ok too. then i updated the drivers nothing help. any idea. Thanks in advance.
    Scholar:
  • 170 Answers
Check the easiest things first, sometimes we overlook the easiest and assume the hardest things first.
Did you plug the speakers back into the right port? It is the pastel green port. Is there a volume control on the speakers? Check that too. Any problems let me know. Tell me how you made out, and please rate my answer.
Posted on Jan 13, 2009
Removing battery of aspire e1-470
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
http://www.youtube.com/watch?v=cg_wvp1YdSI
laptop cmos battery
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Feb 20, 2014 | Computers & Internet
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My aspire L100 will not boot. When on button pressed blue light comes on and then goes off straight away and fan starts Ok but nothing else
    You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
    Aug 05, 2010 | Acer Aspire L100 PC Desktop
    Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
    Hi
    thank you for your query
    Please can you try the following
    1) go to www.devicedoctor.com
    2) Download and install the device doctor software
    3) Once installed open it up and click scan, it will then scan your PC for the best driver
    4) Download the driver (entitled VGA driver) and install
    5) Restart and see if this cured the issue
    Regards
    Shauqat
    Jun 02, 2010 | Acer Aspire L100 PC Desktop
    Will not come on and the network light is allways on
    hi,
    u can try unplug your network card and re-plug it back.
    hope this will help.
    Sep 11, 2009 | Acer Aspire L100 PC Desktop
    No FullScreen
    Either update your flash or re-install the video driver for your laptop. Go to google and lookup Acer Support. Then put the model number in and they should provide drivers.
    Jun 24, 2009 | Acer Aspire 5315 Notebook
    User guide for Acer laptop model 5535
    Hi, I may have a possible fix for this....
    I got an Acer Aspire 5535 for christmas off my parents and on christmas day had a problem where the screen randomly goes off into sleep and cannot wake up unless restarting. This is very annoying!!!
    After narrowing the odds down, i found that after watching vidoes on websites such as Youtube or BBC iPlayer or even iTunes videos my computer went into sleep.
    The only way to solve this... according to Acer - a new video chip needs to be installed so send it off to Acer.
    After this it works fine as i found out after watching Top Gear and the new series of Reggie Perrin on the BBC iPlayer.
    I hope this helps you - i know how annoying this can be.
    Thanks =]
    May 11, 2009 | Acer Computers & Internet
    Hello I have problem my pc acer aspire l100 i have problem power yes light yes job dvd-rw and fan cooler so no screen display monitor only black please can you help me
    Does your laptop beep at all when you turn it on?
    Try unplugging the laptop and removing the battery for 5 mins, then try again.
    If you have another monitor you can use, plug it in to your laptop and see if you can get a display on it.
    Mar 15, 2009 | Acer Aspire L100 PC Desktop
    My microphone on my acer aspire one isnt working
    Hello boannarrow,
    Please try the following:
    Click Start > Control Panel
    If the title of your control panel says "Pick a Category", click "Switch to classic view" on the left hand side of he screen. Otherwise, just follow the steps below:
    Open "Sounds and audio devices"
    Go to the "Audio" tab
    Click the "Volume" button under the "sound recording" section
    Make sure the checkbox by "Select" under Mic Volume is checked, and raise the volume of your microphone here.
    Click OK until you are back in the control panel.
    Try your microphone again. If it still does not work, let us know so we can continue to help.
    Thank you for using FixYa!
    Belgian Alien
    Feb 28, 2009 | Acer Aspire One PC Notebook
    Acer Aspire L100 PC Desktop Logo
    Mohammed Ebrahim M
    Mohammed Ebrahim M
