Question about Nokia E66 Smartphone
Nokia E66: Display issue (lining errors, turn on issues)
My E66 slider has a display issue:
- sometimes when slide open the display doesn't turn on immediately. After a while it lights up and is often with line up errors (mostly in the top or the bottom
- even if the display's looking ok after sliding open it can flash to line up errors when working with it
- also when displaying ok, the display can turn off for a while and then turn on with the errors
  • 1 more comment
  • khunsks Mar 12, 2009
    I have E66. On opening the slide the display goes blank.
    I gave to Nokia Care for repair. They repaired it but the same problem has reappeared after one month. I have given back for repair
    My friend in Thailand has same problem with Nokia E 66. He was told that it is a software issue.
    What exactly is the reason for this?
    Surendra Kumar, Nagpur
  • a_kedy Mar 21, 2009
    Hi there! I have the same problem, it came out right after it felt down from my pocket once. As per one of the local cellphone technician.... there is damaged part inside the phone known as "FLEX", connecting the main-part with the slide-part. How to fix it..??? Probably needs a replacement part... Were to find it..... That's the question of the year.
    Hoping that my comment will help you a bit. Regards, - KEDY -
  • Anonymous Apr 27, 2009
    Search for flex cable Nokia E66 at Ebay.
    It costs about 20$, it seems to be a often fail on this model.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 91 Answers
There is stripe inside the phone which is damaged , and has to be changed look for nokia care around
Posted on Jan 13, 2009
White lines appearing on my Nokia E66's Display
Sounds like the display circuit. You'll need to replace the LCD screen. You can purchase one here www.fix-lcd-screen.com for about $17. Also quite a few YouTube videos on repairs for tis phone.
Feb 01, 2013 | Cell Phones
I have a nokia 7610.when i turn it on, i can only see the white display.i even changed the display.
If changing the Display doesn't help and the phone functions without any issue, then the problem could be related to your phone Display IC. When the Display IC is bad, only the light will be displayed instead of the Pictures or graphics. To fix this issue, you'll need a mobile repair technician so that he/she could check the issue. Please understand that this isn't a task for non-technical guy, in case the handset if opened or repaired without proper knowledge or experience, it could bring permanent damage.
But if in case the phone doesn't work when the display is white eg. No calls can be received, or no messages could be received, then it could also be a problem with the phone software. The same problem could only be fixed by flashing or upgrading the phone software.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 08, 2011 | Computers & Internet
Hie i have SGh e-250i when i open my slide then screen just turns in to white...i cant see who is calling or giving a message...when i turn it down then sometimes it shows a display and some times it...
Thats the problem of display chip. Only solution for it is to visit samsung service centre and replace the display chip. Most slider phone face this problem. I recommend to go to samsung service centre dont go any cellular repaiing as they will not give warrant for new dispaly chip and as per my experience samsung gives 1 month warranty...
Mar 12, 2011 | Cell Phones
I can't reset my nokia e66. I even tried hard reset *#7370# but nothings happen. Is any other way to solve this?
I can't hard reset E66 with *+3+Green+power. The flash works then E66 keeps silently( Doesn't turn on). Pls help to solve. Tks
Sep 07, 2010 | Nokia E66 Smartphone
I have an ipod touch and it is frozin and wont slide ?
  1. Clean the iPad screen with a soft, slightly damp, lint-free cloth.
  2. Do not wear gloves while using the Multi-Touch display. Do not use the touchscreen with wet hands or immediately after applying hand lotion. Moisture affects touchscreen behavior in the same manner as it affects a trackpad.
  3. If you have a protective plastic sheet or film on the touchscreen, try removing it. It may be preventing the touchscreen from working properly.
  4. If that doesn't work, turn the device off and turn it on again. Press and hold the Sleep/Wake button on the top of the device for few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  5. If the device did not turn off, reset it. Press and hold the Sleep/Wake button and the Home button at the same time for a least ten seconds, until the Apple logo appears.
If the steps above don't resolve your issue, please schedule a service appointment with an Apple Retail Store for evaluation. If an Apple Retail store is not an option, contact Apple to find out your best service optio..
May 26, 2010 | Apple iPod touch
IPhone slider won't slide all the way across
I'm having the same issue, have you found any solution?
Apr 30, 2010 | Apple iPhone 3G
My Nokia E66 has a black line on the lcd screen. Pliz can u help
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is the solution! Please vote!
Mar 18, 2010 | Nokia E66 Smartphone
Hi, when i open the slide of my Nokia E66 my display turns blank.
its a hardware fault change ur slide belt (FLAP PATTA)
Aug 18, 2009 | Nokia E66 Smartphone
Nokia E66 screen sometimes goes off when the slide is open...
sounds like the cable is loose and just not getting a good enough connection just because you said after taking it apart it works for a few day then sarts acting up again
Aug 08, 2009 | Nokia E66 Smartphone
Nokia E66 Smartphone Logo
1,552 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
