Why would I find oil underneath an Uberhaus Oil Filled Heater 70395001?
We've been running an Uberhaus Oil Filled Heater in one of our bedrooms for a month now and found what seemed to be oil on the floor underneath it. I've checked the manual and it doesn't say anything about what could cause this to happen - it doesn't appear to have a hole in it anywhere. Do you have any suggestions?
  • 4 Answers
SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Nov 16, 2007
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Posted on Dec 19, 2008
SOURCE: The Lakewood 5500 oil-filled heater has stopped
Similar problem here. But in my case, it was a blown fuse. There's an in-line fuse on the internal wiring of the heater. Take the control-side off (remove the bottom grey plastic bracket, then remove a sheet metal screw, then slide the whole assembly down off of the radiator). Where the elements go into the reservoir at the bottom of the radiator, the white wire should have an inline fuse connected to it. It will probably be covered with what looks like heat-shrink tubing. Snip, snip, and replace.
Posted on Jan 11, 2010
SOURCE: Need Instruction Manual, Kenwood Electronic Heater #EW6708K
I have an original Kenwood instruction Manual for the Model
EW6708EK oil filled electronic heater (eng. and spanish)
Posted on Feb 02, 2010
My heater warms up then it trips out my electrics
Either you have to much on the circuit, like lamps, TV, and running,
or there is a problem with the heater and you should return it.
Try a bedroom outlet, make sure noting is on in all the bedrooms, or the kitchen if you have outlets above the counter, outlets above a kitchen counter are suppose to be on their own circuit.
If you try this and it trips the breaker, return the heater.
Apr 10, 2013 | DeLonghi TRN1015T Solaris Oil-Filled...
Is it cheaper to leave my heaters on?
It works both ways if you are home it will give a constant heat , but is it safe in your place to leave it on while you are out .
Once they are hot they should cut out on the thermostat thus costing less to run .
Dec 08, 2012 | Dimplex OFC1500 Oil Filled Radiator Heater
Brand new mower smoking on first start
tie a rope on the handle and allow it to run for 5-min with no load on it if it doesn't clear up then return it to the store you bought it at
Aug 04, 2012 | Garden
I have a oil filled rad style electric heat ,which is leaking oil can it be fixed? If so how.
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman10
Dec 19, 2010 | Honeywell HZ-709 Oil Filled Radiator...
Oil-filled heater smelling
yeah they do that, time for a good cleaning, if that fails, I'd replace with a ceramic heater... they are cheaper safer and cost less to operate.
Feb 21, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
I had my oil-filled radiator heater on last night in my bedroom, the door was cracked. I had it turned up on the highest settings (both temperature and wattage). Sometime during the night it quit. The...
Let me ask, What did the door have to do with it? :-) Have you chk'd the house circuit breakers. Are you sure someone didn't turn it off? Those units have timers on many models. Did it time out? Plug it in another receptacle and try it one more time before replacing it.They are also thermally protected to prevent overheating in case someone turns it to max near an open bedroom door and goes to sleep. Kidding, but the thermal safety is there If all considered and still inoperative, junk it and get a better one. Good Luck
Nov 19, 2009 | Lakewood Oil-Filled Electric Radiator...
Efficency with Oil Column heating
because it operates on room air temperature, if this is the only means of heat to this room, leaving it on would be more economical thus keeping the rise in air temp time less=less time it works hard to match what you desire. but if not only source of heat no. time to heat room would be almost the same thus you would save what you used during the day due to fluctuations in room temps between time your furnace would kick on and off.
Jun 08, 2008 | DeLonghi 6507L Oil Filled Radiator Heater
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
