Question about Acard Technology (CD1TO7T) CD-RW Burner
"Source drive error" appears in the message window
When first used the acard copied dvds with ease. Now it gives a read error as shown above. I think the original factory settings have been
disturbed by another user. How do I restore them?
  • Anonymous Mar 15, 2014
    when I turn acard pro on it's giving error message advance under run protect
I have Acard similar to CD1T07T0 CD-RW BURNER :
IT SAY " TARGET OVERFLOW" Why when I have enough capacity discs.
Posted on Mar 31, 2009
Error message given is NG:01
No driver is needed for the ARS-2030LD, however a driver may be needed to enable the scsi portion of the controller. Once accomplished, the drive will be auto/detected / auto-installed. I suggest you read the user manual, available here:
http://dl.acard.com/manual/english/ars-2030ld.pdf
then read this page about using sata-scsi controllers: http://www.acard.com/english/fc02.jsp
Your devices may also require a firmware update.
Feb 02, 2014 | Acard Technology (ARS-2030LD) DVD±RW...
Tip
The NASTY "CRC" Error ......Tackle IT
What does CRC(Cyclic Redundancy Check “error”) mean?
There are plenty of technical resources on the Web that discuss cyclic redundancy checks (CRCs). Most times you won't need to worry about this technobabble. That is, until one it day it suddenly appears and you think - what the hell does that mean? In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear.
The most common time you will see the cyclic redundancy check error message is when trying to read data from a damaged CD or DVD. Just before it appears, your CD/DVD drive will probably grind and whirl away - your PC may also become a little slugglish.
Less frequent causes are the result of system crashes, and buggy software (hello Microsoft), incomplete downloads (often identified by the misleading message 'This is not a valid Windows file', 'This is not a valid win32 application' or 'Corrupt Zip file'). If this problem happens frequently with downloads, try using a download manager.
For CDs and DVDs, the problem is a little different. Normally, when CD/DVD drives get a CRC message from a disc, they try to read the disc again - hence the grinding sound. After several failed attempts, they give up and display the redundancy check error. The problem can be hardware (loose cables, failing drive), software or damaged media. In most cases checking and cleaning the disc is the easiest way to overcome the problem. If different clean discs produce the same error, it is likely to be a hardware issue (check the discs in another drive). Another common cause of these errors is poorly burnt CDs and DVDs - especially those that had numerous or severe buffer underuns. USB burners suffer from this problem when the burn speed is too high (generally above 4X-8X)
If the discs are damaged, you'll probably need a recovery tool to get back your data. CDCheck 3 will work for CDs and DVDs. First it will check the media, and then you have the option to recover the files. It's free for personal use and has saved many people heartache when it comes to recovering lost digital images and videos from damaged CDs.
on Dec 22, 2009 | Computers & Internet
Acard 2039A copy problem
If you have access to the lens clean with a tissue or micro fibre cloth In circular motions gentle 10-12 swirls and then try the drive if problem persists then your drive lens have got weak need to replace drive. You have to remove the top cover of drive with 6-8 small screws. It first stops cd reading and writing or just take a specific brand of DVDs or CDs and then It fails over time, it's normal failure behaviour. Pls rate my solution if I helped.
Nov 19, 2013 | Acard Technology Acard ARS-2039A 1-to-9...
Source Drive read disk error
The Cd you are trying to copy may be damaged, take it out clean it and try again, if that doesn't work check that the media you are trying to copy is compatible with the source discs, wouldn't be the first person to try copying a CD onto DVDs or vice versa, an easy mistake i've done this myself
Feb 09, 2013 | Acard Technology (ARS-2030LD) DVD±RW...
DOES NOT BURN CERTAIN TYPE OF DVDS
If it is a cd-rw, as you've indicated above, it will not burn DVD's. The front of the burner will list what it can burn. For instance, my machine says DVD-+RW, which means that it can burn to both + and - DVD's, but it cannot do Dual-Layer (DL) DVD.
Dec 12, 2012 | Acard Technology (CD1TO7T) CD-RW Burner
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Cannot copy 22168504[1]: The file or directory is corrupted or unreadable
Try this quick step:
1. On your windows desktop. Open My Computer. On the drive where you encounter an error right click into it. example the dive C is the source of files to be copied.
2. Click Properties and this window appear on popup and click Tools
3. Click Error Checking and this popup appear, check the two checkbox shown and click OK
4. This dialogue box appear, then click OK, restart your PC and let the scandisk check your PC until it will continue loading to windows. Try copying again your file after checking if it works....
I am happy to assist you. Hope I help on hold problem...
Oct 24, 2009 | Maxtor DiamondMax 6L160P0 160 GB Hard...
Acard 1 to 3 duplicator can't seemto get past the traget disc not ready
of course theres a problem but what are you doing with the thing? are you formaating the disk first to render the dvds in the target drives? are you using the right DVD like DVD+ DVD+- or Blueray? need more information to help you. and it the DVD you are copying has been redered on another machine it won't copy it anyway. You have to use the same machine to copy it as thats how they protect copy rights now days.
May 29, 2009 | Computers & Internet
Windows media player does not play sound on dvds
Go to updates and check to see if there are any new updates to be added
May 17, 2009 | Acer Aspire 5735 Notebook
Acard Technology (CD1TO7T) CD-RW Burner Logo
361 people viewed this question
Top Acard Technology Computers & Internet Experts
Martin Murray
Alun Cox
DROPNDEAL
DROPNDEAL
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
