Question about Panasonic SD-YD250 Bread Maker
Bread does not rise
Using new Panasonic SD255 made 4 loaves. Bread does not rise, or seriously sinks in the middle. Makers recipe and instructions followed to the letter, including use of strong flour.
Latest disaster was rye loaf made with mixed normal rye and strong white flour as per Panasonic recipe: sunk in the middle, with bands of white and dark flour in the loaf which were still flour, still powdery, i.e. had not mixed properly with water. These bands went approx. 1 cm into the loaf.
The only loaf which did work was a rye loaf out of a bread mix packet. This however contained a lot of dubious chemicals we dont want in future.
  • Anonymous May 01, 2009
    Have a Panasonic SD255-tried to make rolls with the machine making the dough-when left out to prove dough did not double in size. Why is this?
  • Anonymous Mar 20, 2014
    I bought a new mounting shaft unit and the problem persisted. Should I buy a new blade? Is it going to resolve the problem?
Bread with a sunken top is likely to be a problem with the Panasonic Bread Machine. This is probably the result of too much fluid and some overactive yeast. First try a bit less fluid. If this does not work, a bit less heat, and a bit more salt should inhibit the yeast. Good luck.
Posted on May 06, 2009
  • 7 Answers
  • Make sure it is good quality Strong White Flour (not plain flour)
  • The amount of water you use is very important. Use scales for accurate results - 1ML = 1G for water
  • Make sure the yeast is as per instructions regards type/quantity/quality.
  • Double check that you are running the correct program.
  • Always put the yeast in first, as you dont want the water in contact with water
Having failed that I would return the machine
Posted on Feb 05, 2009
Panasonic 257 bread and dough not rising
Can you send me the specifics of the recipe you are following? Also please include the type of flour.....all purpose flour, self rising flour, bread flour...etc. etc.
Apr 11, 2013 | Kitchen Appliances - Others
When I make a 3lb loaf of basic white bread and the loafs don't seem to rise at the top and it's like the bread just sinks in the middle
Next time follow the same recipe but remove 2 TBSP of liquid from your measuring cup before putting it in the pan
Feb 18, 2013 | Tefal Emerilware Bread and Baguette Maker...
My bread recipe, which I have used with no problem for over a year in my CBK 200, now produces 2ib loaves the size of 1ib loaves, quite dense. I have tried using new yeast, quick rise yeast, warming the...
can you send me a copy of the recipe you are using? ingredients and amounts and the name of the recipe? I may be able to figure it out that way. Also include the type of flour you are using..all purpose...or bread flour etc....
Dec 13, 2010 | Cuisinart CBK-200 Bread Maker
Loaf falls in the middle and outside is hard
Falling in middle is usually due to innacurate measuring of liquids. Try again using the instruction manual's recipe and very carefully measuring. Be sure to adjust the liquid if you use honey or other liquid not called for in the recipe.
Feb 01, 2009 | Oster 5836 ExpressBake Bread Maker
Bread Rises Beautifully - then sinks in middle during bake cycle
Sinking in the middle means that there was too much rising for the amount of structure in the bread.
Usual causes:
-too much yeast (reduce 1/2 tsp.)
-too much sugar (reduce 1/2 tsp.)
-not enough salt (increase 1/4 tsp.)
-too much water (reduce 1 tbsp)
Another possible remedy: use "best for bread" flour, it has more gluten, or add gluten separately, 1 tbsp.
Start with reducing amount of water.
Jan 04, 2009 | Breadman TR520 Bread Maker
Top of loaf sinks in
I am having the same problem, I have made 3 loaves of white, they all did not turn out, and I played with the recipe a bit to solve it, but I keep getting the same result!
Dec 16, 2008 | Oster 5838 ExpressBake Bread Maker
Having difficulty
Try different batch of yeast. If still a problem increase the amount of yeast and/or sugar. Also if it rises and then falls there may be too much liquid.
May 29, 2008 | Cuisinart CBK-200 Bread Maker
Bread won't rise
We have owned a Panasonic bread maker for ten years and gets used twice a week to make bread using "spelt " flour.About three years ago the bread maker was producing flat loaves,and was very heavy.We contacted bread making company called "Simply No Knead"and asked for there advise,as we were following the same recipe and method for around six years. They suggested that we add a little more water,and this would fix the problem.We tried this and the bread still failed to rise,so we rang them again .This time they said that we need a new bearing in the bread maker and that would fix it.We did this at a cost of $40 and still no good.This happened over a period of several months.We suggested to them that there must be something wrong with the flour,which they denied.After checking the labels on the packaging we noticed that they were using flour from another country [ I think it was Hungary ],because they had run out of suppies from Australian wheat produces.
The flour was far to old,and bread won't rise if the flour is to old. As soon as they started using Australian produced flour again the bread improved dramatically.
Hope this is helpful to you
Dec 11, 2007 | Breadman TR875 Bread Maker
Panasonic SD-YD250 Bread Maker Logo
952 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
