Question about Garden
Echo PB 200 power blower, I have to let it warm up to start having decent power at WOT. then at times it sputters @WOT,then gets back running good again?any suggestions?
  • 413 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
  • 31 Answers
SOURCE: I have an echo pb 265l leaf blower. It starts
If its a two cycle engine it sounds like its loading up on fuel.. Need to lean out the fuel on the carb. Not much or it will be to lean an stick the piston..
Posted on Sep 23, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Posted on Sep 25, 2009
SOURCE: I have the Echo PB 265L leaf blower.
I had the exact same problem with gas soaking my back and found out the yellow fuel discharge tube that comes out of the carberator was not inserted into the rubber gasket on top the fuel tank. The gasket has 3 holes in it for 3 tubes and the yellow tube fits into one of the holes. Hope this helps. It is a bit difficult to get the tube in the hole, but at least if you know what you are looking for you can get it to work
Posted on Nov 09, 2009
SOURCE: I have a Echo PB-260L Blower. It starts fine then
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Posted on Nov 12, 2010
Echo pb 255 throttle cable attachment
try parts tree .com they have decent diagrams..
Aug 27, 2014 | Echo Power Blower PB-255
Have Echo PB 1000 leaf blower that quits running when engine gets hot
Issues like this could well be a ignition unit breaking down when it gets hot.
Jan 20, 2013 | Garden
My Echo PB-251 will not start.
I know you checked the plug, but it can fire outside the cylinder and then not fire under compression.
If you have compression, fuel, and spark at the right time you should get combustion.
Jun 28, 2012 | ECHO, Inc. PB-251C Handheld Blower
Echo pb-620st will not crank
Simply use a srewdriver to adjust the mixture screw. Its located on the carburator. Clockwise is lean, counterclockwise is rich. If you can get the thing to idle, let it warm up first. Adjust the mixture lean until it just starts to sputter, then adjust it rich 1/2 turn. Test full throttle, if it sputters, you can adjust the mixture a little more rich so that it runs good at full throttle.
I would suggest steering away from investing in 2 cycle engines for a pawn shop, unless you can see them running. These little engines are very picky and they only run well if they are in good shape. If you cant get them to start easily, there is probably a lot of internal wear/damage and these engines are hard to find parts and are not cheap to fix.
Bad investments would include 2 cycle leaf blowers, trimmers, chainsaws, boat motors, and motorcycles that do not start easily. Believe me, they are a headache to fix.
Mar 27, 2012 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
I bought a new echp pb-251 blower last year. towards the end of last season the blower seemed to run sluggish. I attributed it to the cold weather and stored it properly with fuel stabilizer. Now here in...
Hi, there is a wire screen in the exhaust outlet that blocks up with carbon deposits. It can be removed and cleaned with a wire brush. If blocked it will give you the problem you have and also make the blower quieter than it should be. Regards Phil.
May 01, 2011 | ECHO, Inc. PB-251C Handheld Blower
My echo pb-201 hand held leaf blower starts and runs for about 2 minutes then begins to sputter and stop. Sometimes I can get it to work for about 4 minutes but then stops.
may be a clogged fuel filter or bad fuel lines check to see if they are real soft if so replace it they are fine the may need a carb kit
Jan 13, 2011 | Echo Garden
SIR. I HAVE A ECHO PB 200 POWER BLOWER..WHAT IS THE FUEL GAS/OIL RATIO? THANK YOU
You can't go wrong with 25:1. Common accepted best ratio for this item to give best life for the internal components.
Nov 15, 2010 | ECHO, Inc. PB-251C Handheld Blower
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
Runs for a little while the blower it is echo pb 620
these do this all the time just let it sit for 10 minutes and it should fire back up.
Feb 26, 2009 | Echo Garden
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
