Question about Health & Beauty
TGA Eclipse runs for about 6ft then stops. Power light flashes 9 times.
Manual indicates that I need to check the parking brake and motor connections and make sure the controller connections are secure - What is the best way and what am I looking for specifically?
4 Suggested Answers
SOURCE: scooter motor does not operate
are you sure its in gear. I had the same problem and I pushed the nob on top of the motor towards the front of the machine and it worked!!!
Posted on Apr 07, 2009
wcdoc1953
  • 280 Answers
SOURCE: I bought this scooter on craigslist, batterys
If the batteries are good, you have solved 80% of most scooter problems. You have described the following problem:
You have a flash code of 9, that is the status light flashes 9 times, then there is a pause, then flashes 9 times again and the scooter will not drive.
This means that you have an internal controller problem. The only solution to this problem is to replace the controller (computer module). The controller is located under a plastic cover under your feet when you are sitting in the scooter. Remove this plastic cover and remove the aluminum cover of the controller inspecting for burnt and melted wiring.
You should have the manufacturer run the serial number for this scooter to verify the correct component parts (Pride 800-800-8586). Pride can also verify if the parts are covered under warranty. Warranty repairs need to be done by a certified technician or a dealer.
The R series controller for this scooter runs $230 retail. All the associated wiring harnesses plugged into it (if melted or damaged) will run another $230. Labor is about 1 hour and you can do it yourself. Take off all the covers and plug the wiring harnesses in one at a time noting how they are run.
I have seen the wiring and plugs melted where they plug into the controller, so inspect this area carefully.
You can test the motor with a digital voltmeter. Unplug the motor and put your test leads across the red and black connectors . The resistance should be between .5 and 1.5 ohms for a good motor. Test the motor brake by reading the resistance across the 2 white connectors. It should read between 30-35 ohms across the brake. Hope this helps.
Posted on Dec 04, 2010
ZJLimited
  • 17970 Answers
SOURCE: my TGA eclipse mobility scooter
Sound like a electrical problem
Keep in mind the new device and its possible that you have warranty for this, you can reach they using the contact details below:
Scooters Mobility Ltd
Suite 3
40 Melton Road
Oakham, Rutland
LE15 6AY
T: 0845 273 9717 (local rate)
F: 01572 801 075
E: info@scooters-mobility.co.uk
Try this before to do something, you could lost the warranty..
Keep us updated.
Posted on Mar 31, 2011
Installed new batteries Service Indicator Light flashing 5x Manual says problem is with Left Park Brake and says check L P B connections. How?
There is a lever on both sides of the chair they are there to make it easy to push the chair without power. both sides need to be in brake mode in order for the chair to operate. If the levers are locked in brake mode then the motor wiring will need to be checked that it is plugged into the controller. A Tech may need to be contacted to help with this.
Apr 03, 2016 | Electric Mobility Invacare Pronto M41...
The led flashes 9 times
9 flashes indicates a problem with the parking brakes. Check to make sure the brakes are engaged and the chair is not in freewheel. there may be a bad connection at the left and right motor connections and brake wiring. Check these connectors for separation and loose, corroded contacts. Reset the error code by turning the chair off and back on once you think you have corrected the problem. Hope this helps
Feb 25, 2014 | Pride Jazzy Select 6 Indoor Power...
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Oct 11, 2013 | Health & Beauty
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Our church has 2 Jazzy's one is blinking the code all lights flash 7 times the other 9 times all lights flash can not find what I need to do in our book. Can you help is there a web site I can get a...
mtp see the below list
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all Hope this helps you
Apr 04, 2011 | Pride Mobility Products Health & Beauty
I need a fuse box diagram for a 2000 Mercury Mountaineer so that I can tell what fuses go to what area's
Fuse/Relay Location Amp Rating
1 20A Moonroof, Adjustable pedals, DSM, Memory lumbar motor 2 5A Microcontroller power (SJB) 3 20A Radio 4 20A OBD II connector 5 5A Moonroof 6 20A Liftglass release motor, Door unlock/lock 7 15A Trailer stop/turn 8 15A Ignition switch power, PATS 9 2A 6R TCM/PCM (Ignition RUN/START), Fuel pump relay 10 5A Front wiper RUN/ACC relay in PDB 11 5A Radio start 12 5A Rear wiper motor RUN/ACC, Trailer battery charge relay in PDB, Radio 13 15A Heated mirror, Rear defrost indicator 14 20A Horn 15 10A Reverse lamps 16 10A Trailer reverse lamps 17 10A RCM, PAD lamp, OCS module 18 10A Reverse park aid, IVD switch, IVD, AWD module, Heated seat switches, Compass, Electrochromatic mirror, AUX climate control 19 - Not used 20 10A Manual climate, DEATC, Brake shift 21 - Not used 22 15A Brake switch, Stop lamps, Turn lamps 23 15A Power mirrors, Interior lamps, Puddle lamps, Battery saver, Instrument illumination, Homelink 24 2A Cluster, Theft LED 25 15A Trailer park, Trailer electronic brake module 26 15A License plate/rear park lamp, Front park lamps, Manual climate 27 15A Tricolor stop 28 10A Manual/DEATC CB1 25A Windows
Feb 25, 2010 | 2000 Mercury Mountaineer
My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
May 17, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
No charge
The brake and the motor are all one piece. To replace the brake means to replace the motor.
Dec 06, 2008 | Pride Jazzy Select 6 Indoor Power...
Health & Beauty Logo
47 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
