Question about Toshiba TP61G60 61" Rear Projection Television
Tobshiba projection screen
Our Tv will turn on but all we get is a blue screen and very low sound. We are having trouble figuring out what is wrong. We are not TV repairers, just normal people wanting to get a diagnoses before we call a repair man in to fix it. Please help.. Thank you, Brenda
    Scholar:
  • 150 Answers
Some have a switch on the back that switches the ceneter mode and will kill the sound, If you have a blue screen there may be a defect in the cable box or the tv may be on the wrong source, might try to change the channel to 3?
Posted on Jul 06, 2007
Turn on tv have sound and picture then screen turns blue no picture but have sound
Blue screens are a strong hint that your tv isn't picking up an image. Check to see if you have a firm connection on both your tv and your input device (cable box/ dvd player). You may want to disconnect and reconnect fully. Also attempt selecting other inputs. If you only have trouble with that one input, then you have a loose internal connection. Also make sure that your TV can display an image by trying to use the on screen controls.
Sep 05, 2010 | Sony KP-53V75 53" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Blue color on screen
If mostly blue shadow appears around the white objects means the cooling liquied is getting dirty and needs to be replaced.
May 27, 2009 | Philips 46PP9302 46" Rear Projection...
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
52'' sony tv rear projection turns blue
it sounds like the blue crt is failing Pull the front off and turn the tv on
When it still has a good picture tap the blue crt
if it flashes blue with lines across the screen then you know it is a bad crt
It might not be worth fixing
Good luck
Jan 26, 2009 | Sony KP-57HW40 57" Rear Projection...
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Hitachi 46f500 screen messed up after welding on same circuit
If you did manual conv. You have to redo it when you replace the bad parts. Them being conv. ic's replace them and check 1/4 watt resistors that are low value right beneath amps. Careful not to solder any foil pads together or you will have major problems. Very common for do-it-yourselfers. Good luck, Russmann.
Jun 15, 2008 | Hitachi 46F500 46" Rear Projection...
Blue picture
im having the same problem hvnt figured it out yet, but when you put the screen on warm instead of standard or cold it helped mine,went from blue to not as bad pink .
Apr 10, 2008 | Acer AL2671W 26 in. LCD Television
Televison & Video Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
