Question about Garden
Snowblower 8/26 yard machine gas leaks from carb when primed
  • 48 Answers
SOURCE: 6 yr old mower starts, won't run
sounds like a plugged high speed jet in carb - you can attempt to prime again , push at least 7-8 times - once it fires continue to push primer to keep running - it may clear out the carb if this doesnt work the carb will need to be removed and cleaned
Posted on Oct 21, 2008
SOURCE: Poulan snowblower with tecumseh engine runs
Hi
This is a common problem with snow blowers becuase they set around more then they get used and the gas gets stale and cloggs up the carb. First thing to try is remove the bolt that holds the carb bowl on and clean it. It should have 1 or 2 holes through the side close to the bottem and 1 hole about half way up. If this doesn't do the trick you need to remove the whole carb disassemble and soak it in carb cleaner.
Sam
Posted on Jan 07, 2010
brado83
  • 106 Answers
SOURCE: I have a tecumseh 5.5hp LH195sp-67514 engine on my snowblower
Hey mate,
First of all check all your fuel lines from your tank to your carb for cracks, with the carb it is common on these to leak past the needle and seat in the carb, I would remove the float and try clean up the needle and seat first, then if that doesnt work you should be able to purchase the needle and seat as a spare part and not have to replace the whole carb...
Most times this problem can be rectified with a quick clean up of the needle and seat as there could be some forign matter or debris under it, be sure to reset the float level/seat turn the carb upside down a check that the float is sitting level or parallell with the carb body...
Hope this helps
Brad
Posted on Feb 05, 2010
Testimonial: "Brad, Thanks brother. I will give it a try."
kel1guy2002
  • 3740 Answers
SOURCE: mtd 22" yard machine staryts and dies using prospray.
Remove the float bowl again and remove the BRASS Jet in the bottom of the venturi throat. Clean the pin hole of the Jet so that you can see through it. DO NOT force anything through it. Just clean it. Underneath the jet is the venturi tube itself. It is also unscrewed with a screw driver. Remove it and clean all ofthe holes in it. Then reassemble tube and jet in to the venturi. Check the BOWL NUT for 2 holes. If the holes are clogged your engine will suffer from a lack of fuel. Lastly check that you have FUEL flow from the tank to the carb. If the tank outlet hole is clogged you will also have a lack of fuel problem.
Posted on Apr 11, 2010
Testimonial: "Thank you for your very helpful advice and detailed insructions as to what to do to correct this problem with starting my mower. runs like new now. Thanks again for taking the time to help me out. Grump."
SOURCE: Yard machine carb issues
clean the main jet and check the pickup tube if this carb is a tank mounted side draft carb.
Posted on Jul 19, 2010
My yard works snowblower keeps filling the base with gas
The float in your carburator is leaking....needs a needle and seat kit. Or turn off the gas supply whenever you are not using the machine.
Jan 30, 2017 | Garden
On my tiller it will not pickup the gas, if i prime it it will run until the primed gas is gone
Make sure fuel is getting to the carburetor if it is take the carb apart and check that the needle and seat and float are working properly.
Apr 19, 2014 | Briggs & Stratton Snowblower Snow Blower...
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Mower starts after priming, then quits. new sparkplug, air filter etc. cleaned bowl still no luck. cleaned out orifices in bowl screw. nothing. Suggestions?
Evan though you cleaned the bowl, the float isn't "floating" correct in the bowl to raise the needle for gas to flow into the carb. The float and needle can be replaced. When you prime an engine the gas shoots straight to the carb. As when the engine is running the floating goes up and down to raise the needle for gas to flow.
Jul 07, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
I have a Toro s 200 model 38130 1979 snowblower. it would not prime no suction when bulb pushed. I replaced the diaphragm with a kit diaphragm first to carb etc. along with new needle valve and spring. Now...
snowblower no fuel . pull float bowl from the bottom of carb the bolt you removed from the bottom to take off the float bowl there will be a small hole in it take a needle make sure to clean it out . then clean out where it threads into .
Dec 03, 2008 | Chevrolet C1500 Cars & Trucks
Sep 27, 2008 | Garden
Garden Logo
244 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
