Question about John Deere Garden
Bh25 le carb schematic
My BH 25 le leaf blower will not draw fuel. I replaced the rotted fuel lines, I noticed that the one return fuel line is blocked, air can not get threw it, looks like a waxy substance in the hole when I took it apart, maybe it is supposed to be that way. Help me please.
  • 4,340 Answers
The waxy substance it gelled fuel. You have to totally clean and blow out all passageways. Resist using any hard tools or drill bits, you want to change NOTHING in terms of size..You just want it totally all cleaned.
Replace all soft parts. Verify the passageways are open. I prefer to soak in carb cleaner, it is strong and nasty, but resolves what you describe. Spray stuff seems to work well, but I worry about areas like venturi discharge systems...Soaking does it.
Posted on Dec 11, 2012
Testimonial: "You are a great sight, thank you so much. I know where to go now if I am stumped"
  • Ronald W Miller Dec 11, 2012
    Mike, thanks so much. I came to Thailand a few years ago, the blower always worked fine before. I usually put a little injector cleaner in the new fuel. The fuel here is not as good as in America. Thanks again Mike.
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
How do I find diagram for fuel lines ?
You should have 2 lines, one supply, and 1 return. If you have a pump primer, it does NOT pump fuel into the carb. It DRAWS fuel thru the carb back into the tank, so its easy to tell which line is which, and also the supply line will have a filter on it.
Oct 08, 2014 | Garden
Won't prime the carburator to start
If the primer buld is hard to push or wont return to shape like its supposed to then there is an obstruction in the carb. If it just wont move fuel then there is a hole in the fuel line or the fuel line is rotted off in the tank.
If the primer bulb itself is discolored ( should be clear not brown) it should also be replaced.
Nov 08, 2012 | Homelite Garden
Need to replace both fuel lines on My BVM200 LE leaf blower, 1 large and 1 small fuel line, can You tell what size they are??
On your blower, it looks like the small line supplies fuel to the carburator which will be connected to the fuel filter in the tank, and the large line looks like the fuel return line.
http://www.ereplacementparts.com/poulan-type-gas-blower-parts-c-16962_31724_131359.html
Jul 19, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Yard broom leaf blower will not stay running I
It seems that the carb is not getting fuel. It could be a cracked fuel line. The fuel priming bulb could also be cracked/dry rotted. Possibly the fuel pump in the carb is bad. The carb is rather intricate and not something anyone without training should try to repair. The overhaul kit will cost $15 to $20. I suggest you take the blower to a repair shop.
Apr 19, 2010 | Homelite 'Yard Broom' Leaf Blower
The fuel line broke and I noticed one only one connection from the carb and two from the fuel tank. I hooked one up and primed it and it ran. What about the other one coming out of the fuel tank? Thanks
One line is hooked to the fuel filter in the tank. It feeds fuel to the carburetor. The other line is a return line from the carburetor. The return connection of the carburetor is on the back side toward the impeller housing.
Good Day.
Oct 05, 2009 | Homelite 'Yard Broom' Leaf Blower
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Which lines hook to what?
Fuel filter to bottom of carb. The suction port of primer to the top of carb outlet line to other port to tank.
To tell which port is outlet put your finger on one port and push bulb if the bulb collapses and doesn't return then that is the inlet (suction) side.
Aug 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Garden Logo
263 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
