Question about Canon Office Equipment & Supplies
CANON IR 1610 SYSTEM ERROR E010 - Canon Office Equipment & Supplies
2 Suggested Answers
  • 62 Answers
SOURCE: canon ir 8500
E010 relates to a main motor fault. A specified amount of rotations has not occurred within a set time. Check motor, see if it turns by hand. If not, inspect and/or replace. Check belts and gears for wear/damage, replace as necessary. E065 relates to a primary charging problem. Suspect primary corona arcing, corona wire broken, High-Voltage PSU may be unservicable, black developer unit may be pulling HVT down. How many copies has each machine done? Recommend calling an engineer, parts are probably required.
Posted on Sep 11, 2007
Error 010 on canon ir 2016
E010-0000 Main motor failure
The main motor is faulty. - Check the connector of the main motor.
- Replace the main motor.
- Replace the DC controller PCB. http://mfpdoc.com/?mod=free&chap=erc&brand=Canon&model=iR2016
Feb 18, 2017 | Canon imageRUNNER 2016 All-In-One Laser...
How to solve error e010 on canon ir 2202 copier
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 22, 2016 | Canon Office Equipment & Supplies
System error E100 in canon ir 1610 how can I clear it. My machine was working I just desided to blow it, it was too dust. That's when the error started. Please help
When you were blowing dust you would have forced a leaf switch sensor into ON position hence this error NEVER BLOW TO CLEAN DUST ALWAYS SUCK DUST OFF INTO CLEANER . A simple tap with your palm all around the printer could set it back if not pro service
Jun 26, 2015 | Canon Office Equipment & Supplies
Canon ir 2018n error code e010
check the drive of the main motor >may be a broken gear .If that is ok then check the main motor in another machine.If that is also okie then u have got urself a fried DC controller PCB.Replace it
Mar 28, 2012 | Canon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
How to solve to check printer cover in canon IR 1610 copier?
how to solve to check printer cover in canon IR 1610 copier
Mar 02, 2009 | Canon Office Equipment & Supplies
Ir 220
E010 codes relate to the main motor or 24v supply through the interlock system. Check for binding in the main drive, or loss of drive voltage.
Aug 26, 2008 | Office Equipment & Supplies
Canon ir 8500
Sep 09, 2007 | Canon imageRUNNER 400S Copier
122 people viewed this question
old marine
old marine
