Question about Grilling
Wire diagram for master forge grill 3218ltn
Repair damaged wires
5 Suggested Answers
  • 4736 Answers
SOURCE: need manual for master forge 2 burner gass grill
If you contact Lowe's, the exclusive retailer for this imported grill, they will be able to provide you with the Owners Manual. Apparently, there were a bunch that made it through without having the Owners Manual.
Posted on Apr 01, 2011
  • 4736 Answers
SOURCE: Master forge grill won't light with 2nd propane
Here's the problem and how to solve it. When you opened the valve on the tank, you did it as you normally would. However, the new OPD Valve tanks will often shoot a heavy load of gas to the regulator and lock it up.
To hopefully solve the problem, do the following:
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow), until the valve is fully open.
Then light the burner farthest for the tank first. Did the burner light and does the flame height
look correct? If so, light the remaining burner(s) the same way. Do all the flame heights look
correct? If so, you solve the problem. Remember to always open the tank valve Very, Very
Slowly.
If that didn't solve the problem, you will need to replace the Grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sell grills and accessories for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy grilling!!
Posted on Jun 28, 2011
  • 4736 Answers
SOURCE: The regulator has a hissing
You will need the replace the grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sells grills and accessories for about $30.00. Take your old one with you for comparison purposes.
After you install the new one, be sure to check it for leaks, as described in the grill's Owner's Manual. Also, and this is very important. When opening the gas tank valve, open it Very, Very Slowly (slow motion, slow). If you don't, the regulator will lock up and no gas will flow to the burners.
Hope this helped you and thanks for choosing FixYa. Happy Grilling!!
Posted on Sep 07, 2011
Kiko Dawg
SOURCE: Master forge grill leaks propane from regator
Not much info given here. But if I am reading correct, a gas leak is on the regulator unit which is attached to the gas line (hose). An entire gas line connection (propane is what I worked with-I'm cetain this will apply to natural gas also.) are less than $15 at your local Big Box hardware store (Lowe's/H-Depot). And they can be easily be replaced by snapping it onto your existing connection. By replacing the entire unit, you should not have to be worrying about any leaks or worse....harmfull accidents to you or your family. Just remember to check your work by applying some soapy (dishsoap) water all around the new connections and make sure no bubbles appear thru the soapy film, indicating a good tight seal.
Posted on Oct 04, 2011
DCER INDISPLAY
This error usually means that your receiver has detected a wiring problem. It has shut down to protect the electronics in the unit. Somewhere, there is a section of wire that has damaged insulation or has come loose. Two wires are in direct contact with each other or a wire is touching the metal of the car.
You'll need to locate the damaged wiring and insulate it or otherwise repair it. After you fix the wiring, you may need to press the Reset button to clear the error. (The location may vary. For most Kenwood receivers, the Reset button is a very small button below and towards the left side of the volume knob.)
If you post the model and manufacturer of the audio receiver, I may be able to give additional information. If the error persists after you fix the wiring, your receiver may have been damaged. In that case, the unit needs professionally repaired.
I hope this helps.
Oct 03, 2015 | Car Audio & Video
Need a manual for Master Forge Smoker Model 32930
I'll save you the trouble. The master forge web site sends you to sears parts. Sears parts does not recognize this model number. This is another example of how Lowes sells mass produces products with little or no customer support. This item was for sale online but is no longer. Online sales is how many box stores remove items from stock that are either out of production or no longer being purchased by them.
Aug 15, 2015 | Grilling
Manual for Master Forge Smoker Model 32938
Go online to scribd they should have it
Aug 03, 2015 | Grilling
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
Where do we bring for warranty, grill purchased in O.C. FL on 6/22/14
The warranty is provided by Master Forge so you have to register your purchase with the company.
Oct 07, 2014 | Master Forge GGP-2501 BBQ Grill Burner...
Gas grill ignighter
Does each knob have its own igniter and do all of them not work
Jun 21, 2013 | Grilling
Master forge electric smoker
There are no manuals to be found for the master forge model, that I have, but I did locate their website of the manufacturer
http://www.landmann-usa.com/
The heating element will not start until the timer is set.
Jun 24, 2012 | Grilling
Need instruction manual for master forge electric smoker
That is the right answer Carla W and it should be down here, not up there where you ask the OP for more information. Answers go down here and you put the Link in where is says link. More Points as well, none up there where you are. :>)
Andrew - Fixya Moderator
Master Forge 20071214
Jun 02, 2012 | Grilling
Grilling Logo
112 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
