Question about Freezers
Vegetable or fruit do not remain fresh they decay within a week
  • 700 Answers
Whats is the refrigerator temperature that you are running, it should be around 34-36 degrees inside of the refrigerator. also wqhat is the humidity levelthat you are running in the vegetable crisper? that shoupld be on highest setting for humidity.
Posted on Jan 13, 2009
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
Danby DFF282WDB stopped cooling - light comes on - any troubleshooting we can do?
Hello;
You are locked into the defrost mode. This is when every 8-10 hours your unit will shut down for 20-30 minutes and your defrost heater comes on and defrost your freezer cooling (Evaporator) Coil. During this cycle everything shuts down except for the light.
Your controls are usually located on the top of your fresh food section. On the bottom of your controls, near the front, left hand side there is a round hole. This is where your defrost timer is located.
With a large flat head screw driver turn clockwise. You will hear a clicking sound. Turn slowly one click a time until your unit turns on. This unit will have to be replaced. Until it is replace manually turn it off every 10 hours for 20 minutes.
Note the round stub on the left.
Feb 23, 2015 | Danby DFF282WDB 10.0 cu. ft. Freestanding...
I have a kenmore upright frost free freezer mod #253.26432100. A couple of months ago everything defrosted and the unit was not running at all. I unplugged it cleaned it and plugged it back in, it turned...
You have a problem with the ADC.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 23, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
Meat spoiled over three week period in standup deepfreeze. Odour Contaminated freezer and general area with meat and fruit spoilage. Have cleaned everything with bleaches disinfectants and commercial...
use a strong solution of clorine bleach(in a spray bottle) to get into every nook and cranny/drainholes/drip trays/door seals and wipe dry(clorine is a gas and will dissipate within an hour or so)then wipe over interior with a damp cloth and plenty of bicarb,leave to dry and leave any bicarb residual inside fridge as this will absorb any smells left.leave door open for about a day in a warm (ish) room, this is the only way of deoderising......
Aug 20, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Foul fish smell emanating from the freezer
Well an old remedy is to put a box of opened arm and hammer baking soda in the freezer and fridge to keep it from having bad odors.If that doesn't work you can try some charcoal it is perfect for absorbing odor, just don't use the matchlight kind or it will smell like lighter fluid.
Apr 06, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezers Logo
83 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
