Question about Xante CL30 HSE Laser Printer
What does error service call 127 fatal error mean on a xante cl 30 d
SOURCE: Xante Cl30 laser printer error
no, but just been told its a P/U issue and going to cost about 300 .replbq{width:100%} var LetterVals = { UIStrings : { __last : 'not used' }, StateDynamic : true, yplus_browser : true, premium_user : true, smsintl : "", SidebarSyncActionType : "read", SidebarSyncAuxActionType : "", SidebarSyncUID : "57", SidebarSyncAuxUID : "", getString : function(id) { var result = this.UIStrings[id]; if ( result == null ) { return "Not translated: '" + id + "'"; } return result; } }
Posted on May 28, 2008
rooboy
  • 24 Answers
SOURCE: Xante Ilumina 512 error code
this error can be caused by a new or existing PC on your network. EXAMPLE: the network settings on new DELL pc's are default set to control the network and repair any conflicts..it seems dells dont like Ilumina's, and they get this error code.
Disable the network control function in the DELL settings.
And this error will not re appear until another dell is installed.
Posted on Jul 23, 2008
rooboy
  • 24 Answers
SOURCE: Xanté Ilumina: 020 fatal error
unplug power. open rear panel (2 thumb screws) check fitting of the ROM chips, restart..
020 relates to Slot A ROM DIMM
May need new ROM, or that CU PCB if unsuccesful
SOURCE: Xante CL30 Fatal Error 127 Code
Printer is now fixed - fan cost £47.00, engineer to fit it was £60.00 (but also gave the printer a service this price). I will attempt to find the exact part number for you.
Beware, our fuser unit was damaged after trying to print too much whilst this error was coming up, and hence we had to buy a new one at a cost of £190!
Posted on Dec 26, 2008
JackHeath
  • 1049 Answers
SOURCE: Xante CL30 Fatal Error 177
I think that's a buffer overflow error, but if you get that error no matter what you print I would check to make sure your memory isn't bad.
Posted on Feb 24, 2009
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
Xante fatal error 929
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
Feb 11, 2014 | Xante Ilumina Digital Color Press Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
Please what can I do to work the machine that says fatal error 133; for xante ilumina
If you are in a Windows OS it means that:
133 JOIN or SUBST command can not be used for a drive that already contains readers joints.
So uninstall your printer and install it again using the best driver.
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
What does error code 032 fatal error mean and how can I fix it
Here's the link to your 500 page Manual. I used the search function at the top of the Abobe Doc which it is formatted as and typed in your error.
It won't call up anything about 032 but Fatal Error recommends only "Call For Service".
Not very helpful is it?
Oh well, please don't thrash my rating with 2 blue thumbs or less. I tried. :(
Regards,
MArcus
Sep 16, 2010 | Xante CL30 HSE Laser Printer
When to many consumable is low at the same time.
Oct 08, 2008 | Xante CL30 HSE Laser Printer
Jun 04, 2008 | Xante Ilumina Digital Color Press Printer
Error 125 is indicating an error detected at MT home position, which means the transfer belt may not be returning to the proper start position. The normal solution to this, if it persists after a restart, is to replace the transfer belt.
Mar 26, 2008 | Xante CL30 HSE Laser Printer
Xante CL30 HSE Laser Printer Logo
35 people viewed this question
Top Xante Office Equipment & Supplies Experts
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
