Question about AEG Washing Machines
Washing machine not taking in water
Used it yesterday fine, today had plumbers over that fixed a tap in the kichen, turned off the mains etc and now the machine doesn't take water in. Its a oko_lavamat 74335 update.
  • rianaj Jan 13, 2009
    Tried all that, still no water in.
Could be air in line washer thinks no water try taking supply off and let air out till water comes out then put back on washer make sure you turn off first lol, and first check to see if the plumber turned supply off for washer by mistake .
Posted on Jan 13, 2009
Water hammer bangs about 6 - 8 times at start up, then stops(furnace humidifier)
get a plumber in to determine the reason for the hammer
if it is unavoidable have him fit an accumulator into the pipes to take the hammer out of the system
possible to change from quick stop taps 1/2 turn or ceramic taps to a tap that takes several turns to stop water flow but normally an accu,ulator fitted into the system will easy the problem
Nov 16, 2016 | Washing Machines
How do I fix a leaking tap
house tap
shut of the mains water supply
remove the insert of the tap
pull out the old washer
( professionals will reset the tap seathere)
fit a new washer
assemble the tap
turn on the mains water
if that is beyond your experience , call a plumber
Oct 08, 2016 | Cars & Trucks
The taps for our kitchen sink are broken inside so the do not turnthe water on.
There are two ways to fix this problem. The first is the most reliable, and the easiest, but unfortunately the most expensive, and that is to call a plumber. The second way involves doing things in order : first, buy new taps, THE SAME SIZE AS THE ONES YOU HAVE, and some thread sealing tape.: second, turn off the water at the "mains" ( this is where the water enters your property, and is recognizable by a tap and a meter ) ; third: very carefully undo the cold water tap (it may take a lot of strength to undo, but BE CAREFUL) ; fourth: now wrap about three inches of the thread sealing tape around the thread of your new tap, and thread the tap onto the pipe. Tighten the thread, turn the water back on at the "mains", and turn your new tap on to make sure it works. If everything is OK , repeat the process with the hot water tap. Good luck, and please rate this reply for me.
Sep 17, 2011 | Washing Machines
I have a Whirlpool 'Splash' 'White Magic' Washing Machine. It was working well except small noise. However, since yesterday it is not sucking water from the tap and all other functions of...
simply put, washers dont **** water from your tap they simply use a valve that opens or shuts to let the water flow through from your taps similar to u turning your tap on just this is done electronically in your washer, if uve got no water coming in your valves are stuck or broken, they are cheap and really easy to fix
Jun 17, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Water hammering after disconnecting a washing machine. I have just replaced our old washing machine that took a hot and a cold feed, with a new washing machine that only takes a cold feed. I have turned...
You can use a water hammer arrestor and hook it up to old washing machine hot valve by use of a standard washer hose. This type of aresstor is basically. a shock absorber. You will needtonget pipe adapters to go from hose thread to pipe thread.If you can mount the hammer arressror higher then the washer valve. Hook everything up and turn old hot water valve back on. This shoulg take care of your problem. Thank you.
Jun 02, 2011 | Plumbing
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Can't turn off taps for cold water hose
if you have the type with little screw in the middle tighten than try again,,,or if you can take it of use a small pliers to turn it off,,onthejob
Jan 10, 2009 | Tricity Bendix AW1200 Front Load Washer
Washing machine will not fill w/ hot or cold water
Could be an air lock in the water pipes,turn off the water to the washer, disconnect the hoses, and hold them over the sink or into a bucket, then turn the water taps back on to the washer.
The water should come through at full pressure.,
If it does not , then the problem is with your supply and not the washer.
Hope this helps.
Plz leave feedback.
Ta.
Dec 09, 2008 | GE WBSE2090A Top Load Washer
Leaking taps
Check first if leaking from hoses or under the machine.
Undo your taps, check that the hoses rubber seals haven't worn out. Replace rubber seals, most hardware plumbing sections have them. Also if the actual tap is leaking at the wall, you will have to change the tappets. You will need to close your main water at the timer, then undo the actual knobs, depending on the tap. Once opened take out tappets and replace with copper ones rather than plastic. Then put all back together and switch water on and check if leaking. In case it is the washing machine, try to replace hose or the connector on the back of machine. Make sure also all rubber seals are replaced with new ones. If under machine you will need a plumber. See how you go!
Aug 02, 2008 | Fisher and Paykel GWL11 Top Load Washer
E02 message
Error relates to water taking to long to get into machine. Check tap is open fully, water pressure is ok, hoses are not kinked. also check the small filters either end of the inlet hoses (inlet valves as well) as quite often they can clog up especialy on a new install. Regards
Jul 22, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
