Question about Braun Series 3350cc Series 3350cc Shaver System Dark Blue Electric Shaver
Braun 350CC Shaver won't clean
When plugging in my shaver to charge and clean, the cleaning mechanism no longer functions. There is new fluid and electricity and it holds a charge. It no longer makes the sounds it used to make during cleaning.
EwingElect
  • 276 Answers
SOURCE: Battery replacement for Braun 8585
I'm pretty sure that the batteries are part of a sealed unit with the PCB on this model, and after checking the Service Diagram I'm even more convinced.
I would suggest fully charging and discharging (leaving it running without the foil and cutter on) a number of times to see if you can improve the performance, as there may be a memory effect on the battey. The model is only 5 years old so your batteries should have a little more life.
It is a mains/rechargeable shaver though, so you "should" still be able to use it with the lead plugged directly into the shaver. So the shaver may not be a dead loss! :)
Posted on Apr 12, 2009
VtToolMan
  • 704 Answers
SOURCE: Braun electric shaver will not charge.
Your batteries are no longer capable of being recharged and need to be replaced.
If you are handy and can dissemble and solder, you can do this yourself, otherwise, you can send it off to a repair service that will do this for you.
If you wish to do this yourself, you'll have to take the shaver apart. There are two (2) small plastic caps on the bottom of the shaver that can be removed with a small pick or flatbladed screwdriver. Once those are out, you can unscrew the two screws that hold the shaver together and gently pry off the side panels.
This will expose the internal circuit board and the rechargable batteries that need to be unsolded. You can then reinstall NEW rechargable batteries and solder them onto the PCB (printed circuit board). You can also purchase a complete internal PCB with the batteries and everything you need, you just swap out the electronics for the new one, although this costs about $39, while the batteries alone are much less.
Put the shell together and reinstall the retaining screws and caps and you're done.
Here's a link to get the replacement batteries for your shaver. They also do the repair service, if you don't want to do it yourself.
http://www.electricshaverstore.com/search.asp?p=1&w=%5F&c=battery&t=s
Hope you find this Very Helpful and best regards!
Posted on Sep 11, 2009
SOURCE: Braun Model 549 series electric shaver
broken screen braun 549
Posted on May 29, 2010
kerguney
  • 577 Answers
SOURCE: Braun Shaver 360 Complete #8985
I though your shaver's built in rechargeable batteries are dead and needs to be replaced..
When this battery is dead it stills show as it was charging while you plug it AC , Blue light functions when plugged in but unfortunately the battery does not hold the charge any more and shaver will not work,
My recommendation is to take the shaver to a repair shop to ask for battery status verification and if necessary for replacement.
Posted on Jun 05, 2010
brector3
  • 1610 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
Can't get the 7526 cleaning arm to stay down on the shaver for charging, cleaning, etc. Is there a sequence e.g. hold the arm down then select a cycle, or select then push down? What is the blue button...
The locking mechanism in the arm is broken. This is a common problem with your model. To repair it you will need to purchase a replacement part. You will find the part at shaveroutlet.com. See link below
If repairing your existing clean and charge machine is not an option, you will find the entire machine available at the link below
May 08, 2011 | Braun Syncro 7526 Electric Shaver
Braun 8585 shaver, charges fine, cleaning cycle acting strange where it thinks the razor is clean, but it is not. When new it cleaned at some level every time put in the cleaning base. Now it very...
The problem is the base, not the shaver. Most likely, the circuit board inside the base has gotten wet and is damaged. If this is the case, it will need to be replaced. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Oct 09, 2010 | Braun 8585 Electric Shaver
My Braun 7526 will no longer clip into the razor for cleaning and charging.
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br /> <br /> arm only<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br /> <br /> <br /> complete base<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
Aug 27, 2010 | Braun Syncro 7526 Electric Shaver
Clean and Renew stand for braun 8595 does not seem to cycle properly...after shaving and placing in unit, it randomly seems to clean and is stuck on cleaning cycle (normal light blinking, no charge) I then...
The circuit board on the shaver may have become faulty. One thing you can try is to fully charge the shaver first, directly connected to the outlet, and then try using the cleaning base. Also, be sure that the fluid level is sufficient. Lastly, you may be able to buy a used but working condition cleaning station off of eBay. New replacements are a bit costly.
May 10, 2010 | Braun Activator 8595 Electric Shaver
Unable to charge the shaver. The charging unit is plugged in, but it doesn't seem to be able to charge the shaver.
The cleaning base is the problem. It probably got wet inside and the circuitry is damaged. This is almost always why these go bad. You dont have to replace it to use your shaver as you now know that you can charge the shaver directly from the cord.
If you want the convenience of the cleaning station, you will need to replace it. You can find a new one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-360-complete-clean-charge-base-p-116.html
Feb 16, 2010 | Braun 360° Complete 8985 Electric Shaver
Braun 5785 does not charge or auto clean via docking unit ?
HOW TO REFILL BRAUN  SELF CLEAN WITH JUST THE RIGHT BREW. THE MISSING INGREDIENT BRAUN DOES NOT WANT YOU TO KNOW
Mar 26, 2009 | Braun 4775 Electric Shaver
Braun 8995 clean and charge stand
Use your Warranty. Or you could simply buy another one and return the Lemon one with the reciept for the new one.
Aug 17, 2008 | Braun Syncro 7526 Electric Shaver
Braun Series 3350cc Series 3350cc Shaver System Dark Blue Electric Shaver Logo
27 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
