Question about Cobra 148 GTL 120-Channels Base CB Radio
Schematic for galaxy dx 959 cb radio - Cobra 148 GTL 120-Channels Base CB Radio
    Genius:
  • Cobra Master
  • 1,795 Answers
Www.cbtricks.com has what you are looking for
Posted on Nov 25, 2014
  • 39 Answers
SOURCE: fuse size
I believe it's 2.5 amp,but you could get away with a 3-5 amp.
Posted on Jan 29, 2009
  • 7 Answers
SOURCE: cb radios
Tweek and peek is minamal on that radio, Finals can not be adjusted but can be replaced with larger ones and the swing limiter needs to be either rebiosed or clipped. Do not try to do this yourself with out the right equipment you will just make it a noisy mess.
Posted on Aug 03, 2009
  • 773 Answers
SOURCE: require mic connections for a 4 pin cobra dx lv cb
This is all the mic wiring information you will need.
Posted on Oct 24, 2010
  • 773 Answers
SOURCE: how to set up the cobra 19 DX IV CB Radio
first keep the manualhandy for the radio and antenna you are using. start by finding a good mounting point for the radio. install the bracket and cheeck the fit with the radio. next run the included power cord from the back of the radio to the fuse box. don't plug it into the radio yet. take the black wire and ground it to metal. try to find a screw goofyinto the metalof the car and loosen it, wrap the wire o. it and tighten it. next find thefuse for the stereo. pull it out and press I back inwith the red wire getting pushed into the fuse socket with the fuse. now you can plug in the radio. IMPORTANT! do not plug it in backwards. if you do you will blow out a diode in the radio and it will not turn on until repaired. turn the key on and then the radio. make sure it powers up BUT DO NOT KEY THE RADIO YET or you will damage it. the radio must never be keyed withough an antenna connected. mount the antenna as close to center of the car as possible le and according to theantennas instructions. run the coax to the radio and connect it tightly. now you need to tune the antenna for best SWR. there is a section in the radios manual and the antenna.manual that explains how to do this. rather then me type it all out you should have detailed I.structins already. if not let.me know and I will ppart it. after the swr is tuned for lowest you are ready to talk on the radio. enjoy.
Posted on Aug 01, 2011
Ironfist109
  • 3018 Answers
SOURCE: cobra 148 gtlcobra 148 gtl DX
  • Hi, here is your users manual http://minus.com/m8geTULWN#1 just click "download" if you want a copy of it. I have a copy of the service manual as well. Let me know if you want a copy.
  • Hope this helps.
Posted on Nov 29, 2011
Adjust modulation galaxy radio
vr 14 is high vr 18 is low vr 16 is fine tune it. but there is a procedure to it so you will need the manual. go to www.cbtricks.com in the left column you will see radios , schematics , manuals.,click on it find g then click the go to galaxy dx and look at the list til you find dx-959 open it up and you will be in your glory. good luck.
Feb 08, 2014 | Galaxy Radios DX-959 40-Channels Base CB...
Tip
Galaxy DX 959 CB radio no transmit or talkback
Hi, I have a problem with this CB radio. The PA works good but after installing the MOSFET kit as mentioned here http://cgi.ebay.com/DUAL-POWER-TRANSISTOR-MOD-KIT-GALAXY-949-959_W0QQitemZ190256621565QQcmdZViewItem?hash=item190256621565&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 it wont transmit and I cant hear myself on talkback nor do I hear the roger beep. The PA amp works though.
on Oct 15, 2008 | Galaxy Radios DX-959 40-Channels Base CB...
What would cause reverse swing on dx 959 galaxy
tuned it to the wrong side of peak.Go back and retune it.You di use a scope didn't you.?
Feb 03, 2014 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy dx 959 radio wont transmitt
I would suspect mic first possibly broken solder connection at jack that inserts into radio.
Jan 06, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Wiring code by number and color for turner mic road king 56 to galaxy dx 959
same pin out as if you were connecting it to a cobra 29.
Jul 19, 2012 | Radio Communications
I overdrove my finals on the galaxy dx 959 by adjusting vr17 too far, now nobody can hear me
you probably blew your audio ic not you final .take it to a tech and let him fix it.
Jun 30, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Need to kwon the numbers for the galaxy santurn base radio to repair it cause the one it has dont belong to it.
What are you needing can you explain more detail. And all the exports base radios are the same schematic as. Are the mobiles. The galaxy 33 and gal 99 are the same radio just the 33 doesn't have the ssb parts
Mar 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Apr 24, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Cobra 148 GTL 120-Channels Base CB Radio Logo
69 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
