How do I connect a turntable to a Pioneer VSX-918V receiver
I have a very nice Harman/Kardon T35 turntable that I want to connect to my Pioneer VSX-918V receiver. I can't seem to find the proper audio connection ports on the back of the receiver.
SOURCE: Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
Magnetic phono cartridges like the one on your pioneer has an output of about .005 Volts, the standard inputs are looking for 1 to 2 volts for fulol out put, the phono preamp will step up the output voltage to 1 volt so you can play it thru a non phono input like Aux, tape or tuner.
Radio shack sells cheap ones and you will hear what you pay for.
I sell turntables and audio gear, check out www.soundsciencecat.com
Good Luck,
Neal Van Berg
Posted on Sep 16, 2008
SOURCE: Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Posted on Oct 15, 2008
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Posted on Feb 18, 2009
dragster301
  • 12 Answers
SOURCE: Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Posted on Jul 31, 2009
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
How can I connect a Thorens 145 turntable to it?
Your Harman Kardon AVR 85 doesn't have "phono" inputs. That means that you can not connect a turntable to it directly. You will need a "phono preamp" to amplify the very tiny signal from the phono cart enough for the HK receiver to play it. Something like this:
PYLE PRO PP444 Ultra Compact Phono Turntable Preamp
will do it. There are certainly better ones, like:
Amazon com TCC TC 750 BLACK Audiophile Phono Preamp Pre amp Preamplifier...
Feb 23, 2016 | Harman Kardon AVR 85
How do I hook up a Pioneer VSX-918V receiver to Sat.Dish box?
For the audio portion, you must have either a digital coax, optical connection or analog L/R composite RCA jacks plugged into the "Sat.audio in" on the rear panel of the chassis. The other end of THAT connection must come from the "audio out/ variable out" from the T.V. or from the Sat.Dish box.
Sep 12, 2014 | Pioneer VSX-918V Receiver
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
Harman Kardon HK 3250 Receiver- how can I connect my turntable? there is no PHONO input
These depends on what model of turntable you have .
On most it can be connected on the inputs you have mentioned ,
If only , a RIAA preamp is included in it.
You may need one, if it doesnt have,
sample phono preamp:
Phonopreamps.com Home Page
can also be connected to Aux or Tape
Oct 08, 2012 | Harman Kardon HK 3250 Receiver
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
hope it worked!!!
Jul 30, 2009 | Pioneer Audio Players & Recorders
No power
Check the fuse
Mar 23, 2009 | Pioneer VSX-918V Receiver
How to connect pionier VSX-918V-K receiver with blu-ray dvd and high definition tv box
The audio OUTPUT of blu-ray dvd is to INPUT to the VSX-918V-K receiver.There are three RCA jack red and white is the audio,the yellow or blue sometimes for the video connect to your TV...
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 23, 2008 | Pioneer Audio Players & Recorders
112 people viewed this question
 Grubhead
Grubhead
