Question about Dell Inspiron 560 Desktop Computer (Intel Core 2 Quad Q8300 1000GB6GB) (DDPDAE431)
How to replace door springs in Inspiron 560
Replacing the fron door spring on the front cover.
2 Suggested Answers
  • 162 Answers
SOURCE: the spring which closes the cover on the front
You can contact Dell Support and ask them to ship the replacement parts. You can also contact any local dealer who can sell the parts much more cheaper rates.
Posted on Jul 13, 2010
How to adjust a swing-up garage door. One doesn't stay up and the other seems real hard to lift
It sounds like the ballast spring/s are broken. They can be purchased at Home Depot. Check the originals to make sure you get the correct ones. Hold the door in the open position using 2x4's one on each of the front corners. Disconnect the spring/s and replace. After replacing the springs you can remove the 2x4's.
Mar 26, 2015 | Building Materials
My CD drive panel stays open/down after a cd has been insertedhe cd works - how do I repair the door unit ?
the exterior door is spring loaded, so the door is either in a bind or the spring is damaged or missing.
If you can't fix the spring/door, you can get a replacement here:
http://shop.ebay.com/i.html?_kw=530&_kw=Inspiron&_kw=front
Jul 16, 2011 | Dell Inspiron 530 Desktop Computer
How do you replace the drive belt in a kenmore dryer model 88042
Pull the fron off. Remove tub, should have a spring loaded idler pulley next to the motor. Make sure that it is not broke and spins freely. Also check tub support rolers on each side. They shoule spin freely. If ok, put belt around tub, install tu. Put belt around spring loaded pulley. May need a hand holding tub while you install pulley. Put front on. Make sure the fron of cover fits inside the tub seal. Good luck. email me with issues, bobby.crochet@lyondellbasell,com.
May 14, 2011 | Kenmore Dryers
The spring which closes the cover on the front ports compartment of my Dell inspiron desk top came off during shipping and the cover disconnected . I can reinstall the cover but don't know how the spring
Jul 13, 2010 | Dell Inspiron Desktop with Intel Core 2...
How do i replace the door hinge on a hotpoint wm80p washing machine
To remove the door springs you just take the bottom front cover off of the dryer.
There are a couple clips towards the top corners that you can release with a flat blade screwdriver.
Once you get that bottom front cover off you will see the springs
Unhook springs from hinge. Remove bolts and hinges
Jun 28, 2010 | Hotpoint Washing Machines
Replacing the door seal on Zanussi 1416W
No need to remove front cover.
Best way round the prob is to stretch the spring, this will make it easier to fit, it will help if you can get someone to assist in holding the spring, so that it does not come off as you are feeding it around the seal.
Don't stretch it to much, as it it will then be to slack, and may come off during washing.
Good luck.
Please rate my solution.
Thanks.
Aug 06, 2009 | Zanussi FJS1225W Front Load Washer
Dishwasher door won't close
OUrs did the same, it was a tiny spring that needed replacing. We just turned off at mains, unscrewed front and took out the unit. Took broken spring out and found one at our local DIY shop. fitted and put back in. ALOT cheaper than replacing the unit!
Oct 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
How do I get the rear ring clamp with the spring back on the front door seal. I took it of ok and have changed the seal but I cant seem to get the spring to strentch enough Thanks Mark LG wd 8013f front...
It takes another set of hands to stretch and hold the spring in place at the 3 and 9 o'clock positions. With the spring held in place in this manner, pull the remaining portion of the spring straight down at the 6 o'clock position with one hand and hold it while working the rest of the spring into the groove with the other hand. This is the toughest part of replacing these door seals, but it works better with two people. Please let me know if you need further assistance. I hope this helps you.
Jul 11, 2008 | LG Washing Machines
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Dell Inspiron 560 Desktop Computer (Intel Core 2 Quad Q8300 1000GB6GB) (DDPDAE431) Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
