Question about Miller SPECTRUM 375 PLASMA CUTTER 903891 115 230 VOLT
Cost to replace the main board miller spectrum 625?
Board is shot and needs to be replaced. what would the cost be?
kevin_max
  • 37 Answers
SOURCE: circuit board flashed resistor
Check this site out.
www.arc-products.com
1-800-770-0063
619-628-1022 Fax: 619-628-1028
service@arc-products.com
Arc Products
1245 30th Street
San Diego, CA 92154
Posted on May 15, 2009
  • 18 Answers
SOURCE: I bought a used miller spectrum 625, can put on
The consumables on the torch head could be incorrect or not installed correctly. check these.
Posted on Oct 07, 2009
SOURCE: how hard is it to change out the main circuit
The replacement of a board is no TOO hard, just DRAW a Diagram of ALL connections when you take the "Old" one out. NEVER work on the machine live Duh, also always wait a bit to allow capacitors to discharge, or use a shorting stick, if in a hurry. Anyhow, make sure you keep all fixtures together note down all connections and label them with little stickers, With any other information on the stickers as need be. I always do this as one never remembers whats what after a bit, anyway. Just be methodical, and you will prevail.
Posted on Feb 25, 2010
  • 4 Answers
SOURCE: pc board for spectrum 375 s/n lh010317p
contact arndt enterprise 847-234-5736
Posted on Mar 07, 2010
  • 225 Answers
SOURCE: Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Posted on Apr 11, 2010
Has cup fault
Check connections on holder and at the main unit. blow out the unit with air to eliminate conductive dust as being a problem. Also make sure cup seating area is clean.
Jan 11, 2012 | Spectrum Miller 625 Xtreme Plasma Cutter...
Miller plasma cutter spectrum 625
make sure your air pressure is high enough and volume does not drop below minimum.
Nov 27, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I have a Miller Spectrum 625. The problem I am having is that after cutting for three seconds the torch quits cutting. Have had it looked at a Miller repair center. They said they cut with it for over...
Hi:
I found similar problem with few customers and one issue (should I said the standard issue) is the source of air. You need a steady pressure and flow of air into the machine. Check your air compressor you will need at least 6 cubic feet per minute (360 cubic feet per hour) and a 90 psi of pressure. Since there is no way to check the flow (unless you have an online flow meter at you air pipe) check the pressure at your air tank (reservoir), if the pressure drops below the 70 PSI then that's the problem; your compressor can't stand the flow. Other than that check your ground clamp and make sure it's making a good contact.
Good Luck.
Sep 15, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
My miller spectrum 701 was set up for 1ph 230 and got plugged into 460 and fire shot out of it several times.what would it take to fix it?
I'm not recommending that you do this, but if you were to open the covers you'd be able to identify visually the blown boards and on the boards are the codes for re-ordering. This is not a guarantee that other boards won't be fault, but they should be ok.
Jun 13, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Hola buen dia necesito que alguien me ayude respecto a una pza de la targeta electronica de la maquina spectrum 625 numero de parte es el siguiente IOR CO621V SA55BA60 . la pza que necesito...
Hola Erick:
Yo te puedo ayudar a conseguirla. Checa el link del diagrama de partes y dime que numero de parte es de acuerdo al diagrama.
http://www.millerwelds.com/om/t2239c_pt_mil.pdf
El numero que pones es el numero de la tarjeta y no lo puedo localizar. asi.
saludos.
Jun 13, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Apr 07, 2010 | Miller Spectrum 375 X Treme Plasma Cutter...
Cant get it to arc or blow?
cant get the plasma to give me a continous arc
Mar 17, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
How hard is it to change out the main circuit board on a spectrum 375 plasma cutter? What is the cost of the board?
Feb 24, 2010 | Miller Spectrum 375 Cutmate Plasma Cutter...
Sep 28, 2009 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Miller SPECTRUM 375 PLASMA CUTTER 903891 115 230 VOLT Logo
239 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
