Question about Necchi 6010 Mechanical Sewing Machine
Threading the 6010 necchi sewing machine
The thread is looping and the thread is breaking
SOURCE: necchi 3101
if you have e-mail I can scan and send you the diagram.
Posted on Nov 09, 2008
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Posted on May 06, 2009
RickE1
  • 202 Answers
SOURCE: I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Posted on Aug 29, 2009
  • 1116 Answers
SOURCE: How do I thread my necchi Lydia type 544 sewing machine
Threading guide - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_542_544_threading_Diagram.htm
Make sure the presser foot is up when threading any sewing machine.
Posted on Mar 06, 2010
SOURCE: The bobbin thread breaks
if upper thread is breaking
1. needle in backward
2.upper tension to tight-check manual for proper setting
3.needle maybe bent-try rolling needle on flat surface to see if it's bent & if so replace
4.thread may hang on bobbin case-check area for lent or fragments of old threads
5. knotty or cheap thread-always use good quality thread
if lower thread is breaking
1.the most probable cause of lower thread breaking is an inproperly wound bobbin
2.bent bobbin
3.lint built up in case
4. thread catching on a spring or latch
Posted on Jul 29, 2010
I need a diagram of how to thread it or a problem solver the thread eeps breaking at the needle
Search the internet for:
Manufacturer + Model + the word "Manual"
or search YouTube videos for "sewing machine threading." You may not find your exact machine, but many machines have similar threading patterns. Be sure to raise the presser foot before threading the upper thread so it will seat properly in the tension disk.
If the thread is breaking at the needle, it could be several problems:
Threaded incorrectly--#1 cause
Upper tension too tight
Install a brand new needle compatible with the fabric & thread
Make sure the thread is not too large for the needle eye
Avoid old, fuzzy, bargain bin thread
All About Needles
Dec 24, 2015 | Necchi Sewing Machines
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
Dec 14, 2015 | Necchi Sewing Machines
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
Necchi sewing machine
There are a number of things that could cause this.
Needle installed with flat in the wrong direction.
Excessive thread tension,top or bottom.
Lack of lubrication. If the machine can do anything more than a straight stitch the mechanism can gum up and not move the needle correctly.
Here is a link to threading directions.
Necchi 3537 Sewing Machine Threading Diagram
Aug 03, 2014 | Necchi 3537 Mechanical Sewing Machine
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Sewing Machines
I am having a problem with the tension on my Necchi. The botton thread tends to loop every few stitches. I have adjusted the screw on the bobbin case, but it still tends to loop. Sometimes the thread...
check the tension on the top thread
check your needle-roll on flat surface to see if it rolls correctly
you might check the bobbin to see if it's warped-I've gotten some that were warped
Sep 20, 2010 | Necchi 3101 Mechanical Sewing Machine
There are loops of thread under the bobbing when i sew
Lift the presser foot and pull about 8" of thread through the needle.
When threading a sewing machine, make sure the presser foot is up as this opens the tension control so the thread can be properly seated and controlled once the presser foot is down.
Apr 23, 2010 | Necchi 4595 Mechanical Sewing Machine
Top thread will not pick up the bobbin thread
Timing is off, is is possible that you broke a needle or sewed over a pin. timing needs to be re set by a professional.
Aug 22, 2009 | Necchi Sewing Machines
Machine tension knob does not work.
Use a better quality thread. Sometime old or cheap thread never works right. Check to make sure you have the right needle for your fabric.
Dec 07, 2006 | Necchi 3537 Mechanical Sewing Machine
Necchi 6010 Mechanical Sewing Machine Logo
61 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
