Question about Whirlpool GEW9250 Electric Dryer
Dryer was working fine then quit heating
It I took a load of laundry out of the dryer put a new load in and turned it on as usual,when I went back out later there was no heat,I took the fron panel off cleaned out all the lent and put back together but still no heat. How easy is it to replace the element and at what cost. It is Whirlpool Model GEW9250PWO-Duet
  • 2 more comments
  • pjellis66 Jan 16, 2009
    Same situation happened to us. Please help.
  • agnesdel Jan 16, 2009
    same here. I put a big comforter that dried just fine but for the next load only cold air came out. We cleanded the exaust but nothing happened. Still only cold air. In the manual is says to replace the fuses but where are they?
  • Anonymous Jan 18, 2009
    Did the same thing, replaced thermistor, worked one day and now no heat again.
  • Anonymous Mar 27, 2014
    this dryer turns on, lights up, but will not run. element heats fine.
  • 686 Answers
Go to www.repairclinic.com enter your model number and your parts will come up for you to see. And to see what they look like good luck
Posted on Mar 12, 2009
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
I changed the belt on my samsung dv219aew/xaa dryer. Put the dryer back together tested once and worked fine. I put a load of laundry in and pressed start and then the power cut off. No lights to control...
if the belt snapped there is usually a reason
some jam up
check that and also there is a capacitor a round white tube
with two connections to it usually bolted too the motor
replace this part
you may find the heating system has a reset feature or thermal fuses
also you may need to replace the mains fuse in the plug or etc mains supply
i think as you put a load in and it cut out
then the start cap is prob short and has blown the fuse
Dec 07, 2014 | Samsung Dryers
Kenmore dryer timer 11086873800
Could be the door switch. Make sure it's closed all the way you should be able to here a click if it is working.
May 05, 2014 | Dryers
Did a load of laundry this morning...took that load out of the dryer, put in another load and when i went to start it.. the dryer would not turn back on..check the wires, dryer vents...switched the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Whirlpool Dryers
Hello,I just picked an electric ROPER dryer last night.I assembled it plugged it in and it worked fine.This morning I put a small load of laundry in it and it worked fine.I then put in a second load and...
The most likely part that has gone out is the thermal fuse. What will make that go out so quickly is a blocked vent causing excessive heat build in dryer. Did the dryer that this new one replaced havea similar problem of not starting or perhaps it ran but took forever to dry a load of clothing? if that was the case the venting caused the problem with both old and new dryer
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Roper Dryers
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Not drying - indicator show AF
you might need to replace the heating element
Sep 05, 2009 | Dryers
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
Kenmore HE2 Dryer makes three beeps but wont start
Check your door closer switch. Mine was doing the same and it turned out to be as easy as changing the switch.
Mar 23, 2008 | Kenmore 62602 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
721 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
