Question about Envision EN-7220 17" Flat Panel LCD Monitor
Help monitor works for 3sec then goes to black screen or dark everything is their you can bearly see it but its their . i droped this monitor an it worked fine till know . I've been told the black lite in it has failed , Can it be fixed
  • Anonymous Apr 03, 2008
    The power light blinks green. The screen is completely black.
    Tighten all connections, nothing.
    Hooked up another monitor, it worked.
  • fuzzgator Jul 25, 2008
    Monitor goes blank after three seconds. Had it for about 1.5 years and no problem till now. Can't do anything to fix it as no screen seen to make adjustments. Still has power.
    Problem Solver:
  • 5 Answers
If the monitor was dropped, most likely you damaged the internal components that provide the picture, whether LCD or CRT. Try connecting it to another computer. If this doesn't work, check the monitor's display settings or operating system display settings for contrast or brightness. NEVER open up the monitor, because there is a high voltage capacitor that stores voltage even when the monitor is off and could kill you if it discharges.
Posted on Jul 28, 2007
My dell inspirion 6000 laptop screen goes black but sometimes I can see the windows screen but it's very dark. When I attach it to a desktop monitor it works fine but the laptop is still dark. Sometime the...
The back light is the whole of the screen, the screen is illuminated by a CCFL lamp (fluro tube) on the bottom of the screen. A inverter supplies high voltage to this CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 08, 2011 | Computers & Internet
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Screen is dark ,tried brightness no work ,was droped but had new screen put on still no joy help would be great
Replacing the screen would not repair any problems with the circuits themselves occurring from the drop. The only option is to purchase a new monitor.
Jan 12, 2011 | E-Machines (T2958) PC Desktop
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
Acer laptop has developed a fully dark screen
I am assuming that you have tried switching from external monitor output and local monitor. There should be a hot key on the keyboard to switch it. Also, try looking to make sure the driver for the display is up to date. I f it was update recently try rolling the driver back. If you need help with doing any of this post a comment. Hope this has helped some.
Dec 02, 2008 | Acer Aspire 3680 Laptop
My monitor works for a little while, then goes black.
Your power-inverter board needs an overhaul.
Probably in need of the standard capacitor replacement.
OR
a bulb in the screen is bad (a bad bulb will usually show symptoms)
It will flicker, or will look pinkishish for a bit or dark in the middle top or bottom of the screen.
ebaysbammbammfran
Oct 11, 2008 | E-Machines eMachines Monitor E15T4
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Panel doesnt turn on
First check all of your connections (power as well as video connections). If they are all secure, then make sure that if there are multiple inputs that you have it on the correct input (by cycling through the sources with the corresponding button). If none of that works then look carefully at your screen to see if you can make out anything on the screen. Sometimes if the LCD inverter goes out then everything is VERY dark. Hope this helps.
Apr 12, 2008 | HP vs15 15"LCD Flat Panel Monitor
Help
It does indeed sound like a backlight problem. Generally speaking, the expense in finding a new backlight and having it fixed isn't worth it considering a new 19" monitor can be had for $150.
Jun 11, 2007 | Envision EN-7220 17" Flat Panel LCD...
Envision EN-7220 17" Flat Panel LCD Monitor Logo
98 people viewed this question
Top Envision Computers & Internet Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Andrew Taylor
Andrew Taylor
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
