Question about Olympus Photography
Olympus lens won't retract, camera won't focus
Lens won't retract and camera won't focus. Monitor is blurry. Was working one day, started doing this the next. The camera wasn't dropped, didn't get wet. We went to use it but the battery was completely dead and wouldn't recharge when we plugged it in. We replaced the battery with one from our other (identical) camera but when it came on, it wasn't working right. (The other camera is perfectly fine with the same battery.) It's about 8 months old and hasn't taken that many pictures. :)
SOURCE: Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
It appears this problem is due a failing CCD device in many brand cameras. All the manufactures use the same source(s). I have not persued Casio as yet, but other companies are offering a recall to replace the CCD for free. I plan to use this approach with Casio. Search the web for "failing CCD in digital camera", it describes exactly what we are observing.
Posted on Dec 02, 2007
  • 3 Answers
SOURCE: lens won't retract and it makes a racheting noise
Most probably and or dirt has gotten into the lens mechanism, could also be a damaged or worn drive gear. Can you see score or scratches on the lens barrel? If the camera is still working then I would keep on using it. A repair would not be economical so a replacement is the only option.
Posted on Jun 30, 2009
SOURCE: Lens will not retract, camera was not dropped,
I turned the dial to "favorites", its the book icon with a heart shape on it. Turn it on. the lens will retract.
Posted on Jul 10, 2009
  • 55 Answers
SOURCE: I want to use my OM2000 Olympus lens for my video
Olympus did not make adapter for OM lenses to be used on Canon XL1 but, if you are looking for the lens adapter, Novoflex XL-OM Lens Mount Adapter Olympus Lens to Canon XL-1, is the lens adapter that suppose to work.
B & H has this adapter for sale.
Posted on Jun 23, 2010
SOURCE: I have a Fuji finepix j38 that is appox. 8 months
I thimk your problem is that you have sand betwin the lens mechanism and that cause the immediately can try to apply air pressure near the lens but with care
Posted on Oct 05, 2010
The lens won't come out - it makes a buzzing noise but won't open. Like it's jammed?? Olympus FE-46
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 04, 2011 | Olympus FE-46 Digital Camera
Its seems lens got stuck in the barrel due to external shock caused, Try out following steps-
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once's or twice then it will stuck again.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else contact Olympus, your camera need to be disassembled to get at the focusing ring at Service Center .
I hope this will solve your problem
Jul 04, 2011 | Olympus Mju 725 SW Digital Camera
My Olympus e 510 is one year old. worked fine, but now is taking blurry pics. I tried all focus setting, including manual setting, auto-focus and even tried a different lens, still takes blurry pics. It...
I have the same problem and I strong suspect the circuit board is going bad. No matter what lens I use, distance from subject, etc. makes any difference. Unfortunately, the fix is about $200.00 - and having to invest $200.00 per year to keep it going is not a viable option for anyone.
Jan 23, 2011 | Olympus EVOLT E-510 Body Only Digital...
Lens won't retract completely. Picture is blurry.
I wish I could offer some simple solution, but the lens has somehow gotten damaged and is no longer able to focus or withdraw into the camera body. It could be as simple as some sand in the lens, but even that will require a trip to a camera repairman
Sep 12, 2009 | Kodak EasyShare V803 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
Blurry screen
it is most common problem you lens focus is out this could be mechanical or a electronical problem.
Sep 22, 2008 | Canon PowerShot A75 Digital Camera
Lens wont retract, view lens blurry
Lens motor or lens servo amp is not working properly. Factory service is require. They will replace the circuit boards and or assemblies as required.
Jerry G.
Jul 11, 2008 | Kodak EasyShare V1003 Digital Camera
Photography Logo
145 people viewed this question
Top Olympus Photography Experts
Are you an Olympus Photography Expert? Answer questions, earn points and help others
